[WTS] Threebond Super Engine Conditioner (Dealers Wanted)
Car Shops and Services
MugenJazzer
157
Threebond Engine Conditioner (Petrol) is an aerosol that cleans the induction system & combustion chamber on your petrol engine by removing carbon, varnish, sludge & gum all without dismantling major parts of the engine.
IMPROVES PERFORMANCE
• REDUCES PINGING
• IMPROVES FUEL ECONOMY
• HELPS SMOOTH ROUGH IDLE
• REDUCES POLLUTION
• HELPS COMPRESSION RATIO
• Use every 15 000km service or 6 monthly.
• Suitable for vehicles with catalytic converters
• O2 sensor safe
• Use only on cable-operated throttle, if electronic throttle consult your dealer BEFORE using.
• NOT TO BE USED ON DIESEL ENGINES - SEE Threebond Engine Condition Diesel 3B-DEC
• No CFC
• LPG Propellant
• Flammable Gas 2
INSTRUCTIONS FOR USE:
1. Warm engine to normal operating temperature. Shake can well.
2. Stop engine, remove a convenient vacuum hose from intake manifold/throttle body.
3. Spray for approx. 15 seconds.
4. Allow to stand for 5 minutes before proceeding to next step.
5. Start engine and accelerate enough so that the engine doesn't stall. Empty remainder of can into intake manifold/throttle body.
6. When can is nearly empty stop engine and allow remainder of conditioner to sit for a further 5 minutes.
7. Re-attach vacuum hose.
8. Start vehicle and run for minimum 2 minutes before road testing vehicle.
THREEBOND ENGINE SUPER CONDITIONER FOR DIESEL is also available! RM80 per bottle. Kindly Whatsapp 0126691601 for details. Dealing method: Post/COD (Kepong area)
come here to give tips and hints about the 2way alarm.
i am using King Eagle. Functional wise is pretty good though the communication range doesnt seems to be as far as stated.
- Question on remote start.
My system crank 'abit' longer than normal turn-key start. Is not axactly overcranking. During normal key start my car only require half second crank whereby the alarm system crank for a second lo.
currently the 'stop-cranking' sensor is connected to 'Check oil pressure'. So i wonder...
