Absorber recommendation
supernt
Jun 15, 2016
10
Hi,
Could someone recommend any good/reliable replacement absorbers for FD1? My budget is below 2k unfortunately.
ixeo
4,788
3,080
KL, Malaysia
OEM? See if Sachs make absorbers for it. Best OEM replacements ever.
supernt
10
There is for Civic FD.
Personally, would you go for Sachs absorbers or AR Racing adjustable (high/low) with body shift? Both new, price difference only about 400-500 inclusive of installation and alignment.
That you got to answer it yourself. The two are actually not comparable.
One is OEM replacement, meaning a balanced ride between comfort and performance for daily commute.
The other is fully adjustable meaning you can lower, raise, tune the damping rate and so on, however the ride is much more harsh (hard and bumpy) even if you set it soft, unless you take the lightest spring rate but to me still will not have the comfort of OEM.
So, set your priorities and go for the one that suits you.....:driver:
supernt
10
Absolutely :biggrin:
What about Tokico vs Sachs?
If aftermarket vs aftermarket they are about the same. Just whether which more durable but then there are pros and cons as some will say A better, some will say B better......hahhaa:biggrin:
Personally having tried Sachs, be prepared for Sachs to be harder than OEM. I don't know about Tokico but last time Sachs in my wira was waaaaaaaay harder than Monroe reflex and all.
ixeo
4,788
3,080
KL, Malaysia
I've used: KYB, APM, GAB SA, GAB SS. And I choose SACHS. Izso is right, its firmer, but I installed it on a boat, so due to its firmer ride, the boat floats less, but it still floats.
Habis cerita. You either get REAL coil overs (no GAB SS aren't real, I'm talking about Ohlins or Bilstein), or just stick to SACHS which is OEM replacement.
once again we are very blessed to be able to get our hands on.......on this rare........designation to highlight its strictly limited production run of 500 individually numbered vehicles, all of which offered for customers to purchase. Each RS500 carries a metal plaque on the centre console, hand-engraved with a unique identification number from 001 to 500...
