Proton Wira ICE Wiring Diagram
digitax
275
Does anyone knows the colour that each wire represents ? Im planning to DIY the headunit myself. The previous headunit was installed by someone and later kena stolen by some assh0l3 who broke into my car, i bought another sony headunit , so can anyone can help a newbie here ?
im just connecting the headunit plus my speakers front and back, dont have amp
thanks!
ExtremeRC
268
Grey -> Right Front +
Grey Black -> Right Front -
Purple -> Right Rear +
Purple Black -> Right Rear -
White -> Left Front +
White Black -> Left Front -
Green -> Left Rear +
Green Black -> Left Rear -
Black -> Ground (GRND)
Red -> Ignition (IGN +)
Yellow -> Battery +
Blue -> ANT/AMP Remote
Orange -> Dash Lights
In this case, ignore the blue and orange wire since you're not installing any amp.
digitax
275
there is another wire which is standalone, wats tat for ?
digitax
275
tried installing the ICE , i phucked up pretty badly ...
i guess i connected the wrong wire, now there is no illumination of the wira digital clock and my centre locking is not working either, any help please ?
i think the wires should be correct, there is power on the headunit but no illumination ? What could be wrong ?
trex92
756
5,018
u must have grounded one of the live wires by mistake and this blew out one of the fuse. Check our fuse box, located under the driver console, look at the diagram and take out the one for clock (if there is any, i can't remember whether got a dedicated clock fuse or it is sharing fuse with another one) and replace it.
cacin
1,000
5
5,138
Penang
Which sony HU are you using? New or second hand? Does it comes with manual? If you claim that the HU is powering and functioning but no illumination, maybe there is a separate wire from the HU that you need to connect to either 12V or your headlight turn on switch.
Do remember to take out the radio fuse from your fuse box during the installation process of you HU if you are lazy to take out the positive terminal from the battery.
Hope this helps.
DarkAccoon
880
432
3,063
ohhh, clock and central locking not working
ehehhe
just replace the 10amp fuce located right underneath the steering rack (more to the right side)
last time also i blew this fuse quiet often
but as i will say
never phucked up, never learn
now am i pretty good at wiring for cars arleady
i am still working on it, but currently i am installing my audio from scratch again
eheheh
will take a while before i finish cause of budget and time needed
as i only get thursday and weekends off
areyoon
6
Thanks for d good info although this topic quite old,but it usefull for me who is new on wira. :congrats:
Dec 23, 2010
4
Hello although I know this is a old post. But may I know how to remove the head unit? Do I need to remove the side of the dashboard to remove or just pull it out by force? I am using stock wira stereo Blaupunkt single din.
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
mcgill...
there was 2 way to remove it...and depends on how the self-locking mechanism for the HU was installed earlier...
if the installer didnt lock properly then u can just pry a bit with small falt screwdriver on both side of the HU.....
but if he lock the HU tightly...then u need to dismantle the meter panel+center dashboard panel(middle aircond passage)+HU panel....all by screw....only when the HU panel was pulled-out a bit,then it would give u access to the back/side of the HU allow u to pry the locking mechanism of the HU.....
:adore: thats from my experience of doing my audio by myself.... :adore:
need to find chop shop contact, those very very old shop.....coz looking for very old stuff...
prefer with contact number.....can call to ask
kl or selangor area
