Aircond Service
cyful
4
www.friendster.com
My car has clock nearly 300,000km, nearly 8 yrs.... never once i do aircond service. Should i be worry as the aircond still good ?
KenDiriwan
1,283
225
3,163
kendiriwan.multiply.com
I suppose you should be able to tell yourself?
But usually by this journey service is required.
If you do a good of keeping your carpets clean, the aircon filter clean, refresh the aircon gases and change the valves, then you should be good to go. No problem don't touch is my belief for aircon.
Beyond 20,000 RPM!
29,998
I thought you new school, service every year......hhahahhah
---------- Post added at 04:22 PM ---------- 6 hour anti-bump limit - Previous post was at 04:20 PM ----------
I am old school and if your air con is still running fine, leave it. With 300k km and 8 years, there may be some corrosion on the cooling fin unit and if you take it out to clean, might just puncture it.
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
just add some oil to the compressor.
if u are willing to spend more then vacuum the system before putting the new oil.
i learn from bad exp of not adding/replacing the compressor oil.
my right rear rim got scratches leh .. my rim color is dark grey .. how much is it to do only one rim? damn my tyre also kena i think .. when i check all 4 tyres .. only this tyre running out of air .. damn ..
tyre tampal can work er? is it posibble to do so? i dont know now .. need to check the tyre again after few days .. if really no air again .. aiyoo .. tyre only run 10,000 km's lah :(
i accidently bang the side just to avoid the pundek mercedez .. :angry: :angry:
afterthat when...
