Charade aura g100
dewagame
Nov 1, 2014
16
Anybody know how to expand the rear wheel side mudguard (i dont know what its name)... i wanna install wider sport rim..
Can u help me please
ken yeang
6,000 RPM
6,617
1,327
This one is like the old proton saga rear wheel arch.
For best result, cut out the top arch, and rework to arching shape. Then you can have as much offset as you like.
Rolling fender or knocking the fender could only move the fender out a bit...
Since you car is already at workshop, might as well cut the top arch out.
dewagame
16
I dont wanna cut tht fender...
Haha...its my own workshop..i paint it myself
Actually rolling the fender only compresses the piece of fender metal that is pointing into the wheel arch. They actually roll in upwards until it meet the side piece of fender to give more space to the tyres in case of more rim offset. To move the fender out from original spot, need to knock out or cut and weld....:driver:
---------- Post added at 04:02 PM ---------- 6 hour anti-bump limit - Previous post was at 04:00 PM ----------
Without cutting, the furthest you can go is to roll the fender. The tyres will be at par with the fender and not out.....:driver:
ken yeang
6,000 RPM
6,617
1,327
try roll the fender, and knock back the arch lips as far in as possible...
Rolling the fender could be tricky for this case, is the arch isnt the typical wheel arch shape.....
Anyway, please share some photo when the project is completed.
ken yeang
6,000 RPM
6,617
1,327
TS, did you do the spray paint in your shed, outside?
Any problem with dust sticking to the paint after spraying?
hi guys....
just bought a set of sport pedals... set of 2 for auto tranny.
my problem is that the new brake pedal is bigger that the original.
the new pedal 4 have screw holes... i was suppose to drill some holes on
the ori pedal so that i can bolt em up.... but it can't be done coz of the
different sizes...
currently thinking of adding a new metal plate to the old pedal.
the new plate will be identical in size to the new pedals...
i'm thinking of welding this plate to the ori pedal...
