Proton Gen 2 ecu wiring diagram/code
vale46
12
Kuching
Anybody know about this? I am planning to install Greddy Emanage or SAFC to my car since I've BOT my engine and I got complete wiring diagram of my car but I don't know whick one to pick up. This are the sensors I've found: knock sensor, o2 sensor, combine MAP/MAT sensor, camshaft angle sensor, crankshaft angle sensor, ignition system, throttle position sensor and all 4 injectors. I can't find RPM signal wire to the ECU. Fot those who know about it, please inform me. Thanks in advance.
Jan 24, 2010
Hi , u can tap from crankshaft sensor +ve side for RPM. I was installed smt6 piggyback to my campro.
May u share your wiring diagram with me ? My email is [email protected]
My phone is 0132760845
Thanks
---------- Post added at 11:39 AM ---------- 6 hour anti-bump limit - Previous post was at 11:36 AM ----------
Stock FPR for campro is 3.5 bar. Look at fpr body . Written they.
Thanks
rowanromano
30
1,508
pin out #59 vehicle speed signal
pin out #60 engine speed signal
hope this may help u... :biggrin:
mivec_0102
11
Hello can u tell me and show me with the o2 sensor in the ecu port and wire.i cannot found it.because i want to tap the o2 sensor reading.
hope can help me.
Jul 22, 2010
Singapore
Hi where can i get the ecu diagram for siemens ecu for proton gen 2. Its urgent need to do troubleshooting. Pls pm me the diagram or email me thks.
Jan 31, 2010
kangar
Please email me also the wiring diagram.
[email: egrgtem
@gmail.com[/email]
Thanks so much
---------- Post added at 10:31 AM ---------- 6 hour anti-bump limit - Previous post was at 10:26 AM ----------
My email: [email protected]
Thanks.
How to stick boost gauge on dashboard? i'm using double sided tape but due to heat and stress from the pull of the hose, it fell off. any idea what to use?
