EJ-DE on Kancil - Zerotohundred.com
Zerotohundred.com
HOME FEATURES NEWS FORUMS THE MARKETPLACE TIMETOATTACK!
Go Back   Zerotohundred.com > Car Discussions > Car Talk
Reply
Tools Search this Thread Display Modes
Old 10-27-2010, 08:57 PM   #1
E6XLancer
250bhp Stage II Member
E6XLancer's Avatar
Liked: 6 / 6 Posts
Default EJ-DE on Kancil
does anybodies here feel the top speed for EJ-DE using on Kancil Chasis with stock 850cc manual gearbox...how about for the fuel consumptions...it is really more save than Kelisa 1.0cc...
E6XLancer is offline   Reply With Quote
Old 10-30-2010, 06:21 AM   #2
kancilkoo
5bhp Stock
kancilkoo's Avatar
Liked 1 Time in 1 Post
Default Re: EJ-DE on Kancil
im using ej-de on my kancil660..but with 1.0 gearbox..
for long distance, its about 25km/l with ron97
kancilkoo is offline   Reply With Quote
Old 11-09-2010, 08:30 AM   #3
realplayer
realplayer's Avatar
Liked: 3 / 3 Posts
hi kancilkoo..afew question here....izit EJ-DE is a kelisa engine??..how much you pay for engine + installation?..thanks..
realplayer is offline   Reply With Quote
Old 11-10-2010, 12:05 AM   #4
subaruimpreza81
subaruimpreza81's Avatar
Liked: 5 / 5 Posts
i use kelisa 850 engine to kancil 660 body + 660 gbox.
RM40 ron97 (Bhp) = 42Xkm
subaruimpreza81 is offline   Reply With Quote
Old 11-10-2010, 04:19 PM   #5
kancilkoo
5bhp Stock
kancilkoo's Avatar
bout 2.5k for the engine n install..
700 for gearbox (mod ds)
Old 11-16-2010, 07:36 AM   #6
hammer13
1bhp Stock
Liked: 0 / 0 Posts
got a 2007 k3-ve engine for sale ..came from a toyota bb.
hammer13 is offline   Reply With Quote
Old 12-17-2010, 01:02 AM   #7
boxxie
Liked 2 Times in 1 Post
can a k3-ve install in kancil? do they have same engine mounting?
and for the EJ-DE, do they have same mounting with kancil too?
boxxie is offline   Reply With Quote
Old 12-17-2010, 07:56 AM   #8
subaruimpreza81
Liked: 5 / 5 Posts
EJ-DE same base with kancil.
k3-ve??? maybe... with lot of money n runner...
Old 12-22-2010, 09:17 PM   #9
E6XLancer
E6XLancer's Avatar
Liked: 6 / 6 Posts
subframe & chasis needs some modifications...im thinking 100% no endorsement can done with JPJ even those saying them are Most powerful Runner...
Old 12-23-2010, 12:50 AM   #10
budakkampungaje
budakkampungaje's Avatar
Liked: 37 / 29 Posts
EJ-DE spec but this spec for japan...
Displacement, cc 989
Engine model EJ-DE
Max.power (Net), kw(PS)/rpm 60 ps (44.13 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 9.6 kg*m (94.14 N*m) / 3600 rpm
Power density 14.83
Engine type Water coolingserial 3 cylinder DOHC12 valve
Engine information Horizontal ranging
Fuel system EFI (electronic fuel injection)
Turbocharger No
Fuel type Unleaded regular gasoline
LEV system (Low emission vehicle) No
Compression ratio 10
Bore, mm 72
Stroke, mm 81
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 5.1
Fuel consumption at 60 km/h, l/100km
same engine EJ-DE is EJ-VE....
Engine model EJ-VE
Max.power (Net), kw(PS)/rpm 64 ps (47.07 kw) / 6000 rpm
Power density 13.75
Engine information
Turbocharger No
LEV system (Low emission vehicle) Yes
Bore, mm 72
Stroke, mm 81
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 6
K3-VE 1.3 DVT...
Displacement, cc 1297
Engine model K3-VE
Max.power (Net), kw(PS)/rpm 90 ps (66.20 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 12.6 kg*m (123.56 N*m) / 4000 rpm
Power density 10
Engine type Water cooling serial 4 cylinder DOHC16 valve
Engine information DVVT horizontal ranging
Turbocharger No
Bore, mm 72
Stroke, mm 79.7
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 5.4
K3-VE2 DVVT n/a this is my favorite engine for k-car...
Engine model K3-VE2
Max.power (Net), kw(PS)/rpm 110 ps (80.91 kw) / 7000 rpm
Max.torque(Net), N*m(kg*m)/rpm 12.8 kg*m (125.53 N*m) / 4400 rpm
Power density 8.18
Turbocharger No
Fuel type Unleaded premium gasoline
Compression ratio 11
Bore, mm 72
Stroke, mm 79.7
Final gear ratio
K3-VET....DVVT turbo
Engine model K3-VET
Max.power (Net), kw(PS)/rpm 140 ps (102.97 kw) / 6400 rpm
Max.torque(Net), N*m(kg*m)/rpm 18.0 kg*m (176.52 N*m) / 3200 rpm
Power density 6.79
Engine type Water cooling serial 4 cylinder DOHC16 valve IC turbo
Engine information Horizontal ranging DVVT
Turbocharger Turbo with intercooler
Compression ratio 8.5
Bore, mm 72
Stroke, mm 79.7
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 6.4
budakkampungaje is offline   Reply With Quote
The Following User Likes budakkampungaje For This Useful Post:
E6XLancer (01-23-2011)
Old 02-03-2011, 03:56 PM   #11
anxereus
1bhp Stock
Liked: 0 / 0 Posts
kancil koo..where did u make the enjin mod??
anxereus is offline   Reply With Quote
Old 10-21-2013, 11:50 AM   #12
kanthang
5bhp Stock
Liked: 8 / 3 Posts
Bro, I am interested in the engines you have listed here. Can you give me an indication of the costs at present and a reliable source. I am planning on changing my stock Kancil 850ex carb engine for a higher cc with EFI. Thanks in advance
kanthang is offline   Reply With Quote
Old 10-21-2013, 12:00 PM   #13
4gbanger
1000bhp Senior
4gbanger's Avatar
Liked: 367 / 283 Posts
i did saw one kancil with K3VET in johor. but im very damn sure it cannot be registered. there are even 1 kancil that install 1.6L detomaso engine in nilai/seremban area... big balls
4gbanger is offline   Reply With Quote
Old 10-22-2013, 05:39 PM   #14
Supra_Fanatics
Supra_Fanatics's Avatar
Liked: 3,997 / 2,658 Posts
K3VE or K3VE2 in Kelisa is good enough for me...
__________________
The Only Person You Should Try To Be Better Than,
Is The Person You Were Yesterday...
Supra_Fanatics is offline   Reply With Quote
The Following 2 Users Liked Supra_Fanatics For This Useful Post:
4gbanger (10-23-2013), twistedichc (11-16-2013)
Old 11-16-2013, 04:45 AM   #15
twistedichc
2000bhp Senior
twistedichc's Avatar
Liked: 255 / 204 Posts
Quote:
if k3vet fliptronic gear can install in kelisa, I want 1
twistedichc is offline   Reply With Quote
Reply
Previous: Previous Thread | Next Thread :Next
Search this Thread:
Advanced Search
Display Modes
SEARCH
Our YouTube Videos
2000 - 2018 Zerotohundred.com - The Automotive Enthusiasts' Network | Tags | Terms of Use | Visitor Agreement | Privacy Policy | Contact Us | Privacy Statement | Top
