Help!! Proton Wira 1.3 locking problem. - Zerotohundred.com
Zerotohundred.com
HOME FEATURES NEWS FORUMS THE MARKETPLACE TIMETOATTACK!
Go Back   Zerotohundred.com > Car Discussions > Do-It-Yourself Garage
Reply
Tools Search this Thread Display Modes
Old 10-21-2010, 09:16 AM   #1
ch1103
Liked: 0 / 0 Posts
Default Help!! Proton Wira 1.3 locking problem.
Any sifu, help needed!! It's a very annoying problem. I've owned a proton wira 1.3 carb. De problem is de locking. It comes with an alarm system. When I unlock de door by either using key or remote control, de lock for all 4 doors pops up and down for many times. Furthermore, even when de door is unlocked, when I closed my passenger door, it will automatically pop down(locked). So, sometimes I got a problem by locking up my key inside de car. Sifu sifu pls help me recognize de problem. Currently a student, not very affordable to fix this kinda simple problem outside by sending few hundred bucks. Prefer DIY all de time for low budget. Hehe.
ch1103 is offline   Reply With Quote
Old 10-21-2010, 09:24 AM   #2
yeehau86
yeehau86's Avatar
Liked: 2,424 / 1,398 Posts
Default Re: Help!! Proton Wira 1.3 locking problem.
check your central lock system and the driver's side's "gun". Is the "thing" pops up completely or partial only? Last time my wira case was pop up partially then goes down back, so the reason is due to the "gun" almost malfunctioned. So I need to change the "gun" and there are two types in the market: OEM type is square shape black colour while the aftermarket type is like a batang shape with light blue colour. See which one you prefer.
__________________
yeehau86 is offline   Reply With Quote
Old 10-21-2010, 09:26 AM   #3
DanzEterna
DanzEterna's Avatar
Liked: 3,370 / 2,068 Posts
yup, gun problem, u wan cheap, go to brothers.
DanzEterna is offline   Reply With Quote
Old 10-21-2010, 04:27 PM   #4
kian27
50bhp Junior
kian27's Avatar
Liked: 5 / 3 Posts
I used to have the same problem like you -automatic pop up & down problem before. But the problem gone by itself .....
the gun wont cost u more than 50buck each, if i nt rmb wrong .
kian27 is offline   Reply With Quote
Old 10-21-2010, 09:13 PM   #5
ch1103
Liked: 0 / 0 Posts
I think it's not the gun prob.. The "thing" pops up completely.. And BTW I've tried changing guns as well.. to de Blue 1 that u mentioned.. Problem still persist..
Old 10-22-2010, 07:51 AM   #6
yeehau86
yeehau86's Avatar
how about the central locking system? try to check on that, it could be the culprit.
__________________
Old 10-22-2010, 09:58 AM   #7
ch1103
Liked: 0 / 0 Posts
sorry.. But which one will be the central locking system? Is it the one located next to the accelerator pedal?
Old 10-22-2010, 12:01 PM   #8
keevan
keevan's Avatar
Liked: 31 / 14 Posts
Quote:
Hi Bro...try to unplug the central looking alaram, i think it should be next to accelerator....then try lock and unlock using ur key...if no problem then its ur alarm causing the problem... if still got its might be the gun or ur central look relay having the problem
keevan is offline   Reply With Quote
Old 11-05-2010, 11:23 PM   #9
ylkien
Liked: 3 / 3 Posts
The central locking unit is right below the steering wheel. It looks like an oversized relay.
Might want to check the central locking wiring. This is how it works :
1) Normal condition
- The control circuit is in CLOSED condition (meaning always connected)
2) Unlock
- The control circuit is connected to ground (for a while)
3) Lock
- The control circuit is in OPEN condition (meaning no connection) (for a while)
Hope this helps.
__________________
Selling some Wira & Toyota stuff ! PM me for details
ylkien is offline   Reply With Quote
Old 11-09-2010, 02:55 PM   #10
ch1103
Liked: 0 / 0 Posts
Thanks bros.. I've already solved de prob by 50%.. LOLX! I've disconnected both of de switch wire.. So i can only lock n unlock using de alarm remote control or de switch from de alarm system to unlock.. but de cons is, when im gonna open it manually from de driver side, the others wont pop up.. lolx! which means if im using de key to open de door, only de driver side will be popping up..
Reply
Previous: Previous Thread | Next Thread :Next
Search this Thread:
Advanced Search
Display Modes
SEARCH
Our YouTube Videos
2000 - 2018 Zerotohundred.com - The Automotive Enthusiasts' Network | Tags | Terms of Use | Visitor Agreement | Privacy Policy | Contact Us | Privacy Statement | Top
