abnormal sound on the front suspension - Zerotohundred.com
Zerotohundred.com
HOME FEATURES NEWS FORUMS THE MARKETPLACE TIMETOATTACK!
Go Back   Zerotohundred.com > Car Brands > Car Manufacturers > Honda
Reply
Tools Search this Thread Display Modes
Old 07-04-2010, 08:52 PM   #1
skyline2m
Liked: 2 / 2 Posts
Send a message via MSN to skyline2m Send a message via Yahoo to skyline2m
Default abnormal sound on the front suspension
when i drive and pass through a bumpy road there are a sound like "tok, tok, tok"
is this sound is the front arm got problem?
my car is ek3
is all honda civic will have the same arm problem sound?
skyline2m is offline   Reply With Quote
Old 07-04-2010, 08:58 PM   #2
basikal_pancit
basikal_pancit's Avatar
Liked: 54 / 19 Posts
Send a message via MSN to basikal_pancit Send a message via Yahoo to basikal_pancit
Default Re: abnormal sound on the front suspension
i have same problem.. but ep3
basikal_pancit is offline   Reply With Quote
Old 07-04-2010, 09:15 PM   #3
Jakk
Jakk's Avatar
Liked: 84 / 52 Posts
will ur car feel imbalance?
my experience is :
my rear passenger side absorber will came out a sound of "dok" when going thru road bump or sometimes uneven road, and i can feel the "drop down effect" to rear left side of the car.
problem havent solve, btw my car is prelude.
Jakk is offline   Reply With Quote
Old 07-04-2010, 09:41 PM   #4
shah5755
shah5755's Avatar
Liked: 31 / 24 Posts
try to check ur lower arm bush bro....face this probs b4 and check undercarriage found lower arm bush faulty already.......simptoms got tok...tok..tok...sound uneven road and during driving feels a bit 'lari' ( hw to mention in eng????)
shah5755 is offline   Reply With Quote
Old 07-04-2010, 09:48 PM   #5
Jakk
Jakk's Avatar
off allignment?
Old 07-04-2010, 09:59 PM   #6
shah5755
shah5755's Avatar
haiya always went to workshop and told pomen like that mar
can be consider bro off alignment
Old 07-06-2010, 12:07 PM   #7
rakyat
rakyat's Avatar
Liked: 36 / 16 Posts
Quote:
my experience is :
Most likely due to worn out bushing or absorber. I oso have same problem and thot it was absorber. Changed the absorbers and still got sound, poreman say it is 'suspension problem'
Change bushing very xpensive1
rakyat is offline   Reply With Quote
Old 07-06-2010, 10:30 PM   #8
shah5755
shah5755's Avatar
replace my front bushing few months ago using genuine parts cost me around rm1300 including labour etc
like it or not wat to do someday u'll need to replace it earlier inspection can save ur pocket and ur car bro....
Old 07-06-2010, 11:18 PM   #9
E-Tech
E-Tech's Avatar
Liked: 255 / 98 Posts
What i did?
Change the both arm units assembly L & R with arms from a good half cut ek9...
Problem solved.... undertable RM300 settled....
:-) newer looking calipers, thicker disc and etc.... most important tak tak or tok tok gone...
E-Tech is offline   Reply With Quote
Old 07-07-2010, 09:16 AM   #10
arturo
nooB
arturo's Avatar
Liked: 1,084 / 645 Posts
seems like a lot of honda owners having this problem eh...
i also had this problem. still having it in my both my rear suspension. its the bushing. jack the car up...take a metal rod n push all the connecting arms n check all the rubber bush for cracks...any rubber that shows cracking or excessive movement of the joints mean the bush is passed its lifetime. Honda bushing are expensive and from my experience, halfcut bushings will not last very long. remember my rear? the passenger side lower arm was changed to a very good condition halfcut lower arm about 2 years ago and it's gone now. both connecting bush is cracked and moves around. long term solution? try aftermarket PU bushing. very stiff and uncomfortable but makes the ride sharper and will definitely last longer. downside is the price. last i checked prices will cost more than double new original replacements.
anyway...after u do find out what's the problem...do let us know. at least we have a solution to yr tye of problem and other forumers can read n learn...
arturo is offline   Reply With Quote
Old 07-07-2010, 09:53 AM   #11
rakyat
rakyat's Avatar
Yup xpensive repair... if you change F&R probably > RM2k....
Actually do we really need to replace it? My bushing been rosak for 2 yrs now still haven't change, just some annoying sound when pass thru bumps, alignment lari abit and steering abit longgar.
I think most older cars out there have wore out bushings and ppl hardly change it.
FYI I intend to chage my bushing but many poreman reluctant to do it! Probably difficult job and most of them do not have the press machine.
Old 07-07-2010, 10:09 AM   #12
arturo
nooB
arturo's Avatar
bro...front suspension setup kenot play play la...at hi speeds, when brake it will pull to 1 side 1. and if on uneven road will pull even more and cant agak which way will pull. the worse thing is tyre will have uneven wear on the inside. rear can still forget about it for a while la...but the front side very important...esp on vtecs that pull very suddenly during vtec cut in. u dont wanna be opening vtec n suddenly pull to left n knock into a motor mah hahahahah
Old 07-07-2010, 10:44 AM   #13
rakyat
rakyat's Avatar
Ya-la the car pull to 1 side (left side) but it is not so severe until lose control. Oso my VTec hardly open1 uncle-mah but it is good to know the power is there if needed
Frankly speaking, I already spent RM2.8k on the absorber and to spend another RM2k on the bushing on a < RM20k car without increasing HP
Will probably do it change it but not so soon; anyway OEM or PU? Hardracing or SuperPro?
Old 07-07-2010, 11:22 AM   #14
arturo
nooB
arturo's Avatar
i'm more towards using OEM ori parts...but sometimes, the ori parts r just not good enough. i believe the bushings have this issue. PU will definitely last longer since it doesnt degrade like rubber...but the stiffness might be a problem. cant comment how stiff the suspension will get tho...just from what i heard from ppl who have installed...
anybody here installed PU bushings?
Old 07-10-2010, 12:34 PM   #15
shah5755
shah5755's Avatar
mine after installed new bushing using the genuine parts got many rattle snake inside cockpit area loose sound from dashboard,door panel....
Reply
Previous: Previous Thread | Next Thread :Next
Search this Thread:
Advanced Search
Display Modes
SEARCH
Our YouTube Videos
2000 - 2018 Zerotohundred.com - The Automotive Enthusiasts' Network | Tags | Terms of Use | Visitor Agreement | Privacy Policy | Contact Us | Privacy Statement | Top
