to remove and replace waja door handle
scoupe
1,087
37
5,148
shah alam
hey guys, my waja door handle broke yesterday.. im going to go get a new one but i need to know how to install it.. seems easy but im not sure my self.. its the handle outside the car..
lonelylilpig
832
33
Better u send to workshop bro, if u make a simple mistake u have to remove the hole door panel...
If u're good enough there's a trick to replace it without remove the door handle. It only requires a long 2" philip head screw driver, 1 ( not sure size 10 mm / 12 mm ) allen key, 1 bright enough torch light and good skill in hole digging.
The hole is locate at the side of the door.
keisukosan
316
7
lonelylilpig say is right...if u wan do urself than u can try it with skill have teach u
scoupe
1,087
37
5,148
shah alam
i heard about that screw thing on the side of the door.. anymore info u can provide me with?? i rather do by my self cause it saves me the hassel of sending the car to workshop..
lonelylilpig
832
33
my advise better send it to workshop. If u accidentally unfasten the bolt too much u'll get 10x more hassle !!!
scoupe
1,087
37
5,148
shah alam
i have successfully changed the handle my self.. i did not remove the screw instead i cracked the old handle and removed it.. the new one fits well.. the difficult part was removing the old one.. the new one just slides into place..
scoupe
1,087
37
5,148
shah alam
erm no.. i left the sensitivity as original.. i think the difficult part here is removing the old handle.. the new handle took 10sec to put in..
Aug 17, 2009
Ampang
my door waja handle also broke yesterday. can u explain step by step to do it and what tool to use. really apppriacate it....
scoupe
1,087
37
5,148
shah alam
its like this la.. i tried removing it properly but it took forever.. then i resorted to just cracking the old handle and removing it.. cause installing the new one is a very simple procedure.. just put the latch into the socket, and cue the handle in a angle into the door.. hope it helps..
Hi Perodua Alza owners,
Greetings from Lokatoo. We are here to give you updates on your Lokatoo GPS navigator and also to help you with any issues you may encounter. Please feel free to ask us any questions you may have regarding your Lokatoo usage.
---------- Post added at 09:03 PM ---------- 6 hour anti-bump limit - Previous post was at 08:58 PM ----------
Latest map version 3.26 is now available for downloading from our website for...
