To take care of turbo engine - Zerotohundred.com
Zerotohundred.com
HOME FEATURES NEWS FORUMS THE MARKETPLACE TIMETOATTACK!
Go Back   Zerotohundred.com > Car Discussions > Car Talk
Reply
Tools Search this Thread Display Modes
Old 08-23-2009, 10:29 AM   #1
melanz
5bhp Stock
melanz's Avatar
Liked: 0 / 0 Posts
Default To take care of turbo engine
I choose to use 4age sivlertop with addition of turbo charger. How to take good care of this type of combination. plz give advice
melanz is offline   Reply With Quote
Old 08-23-2009, 02:36 PM   #2
turbolover
Liked: 112 / 66 Posts
Default Re: To take care of turbo engine
Eh nobody seems to be answering this thread yet.must be sunday and everyone went out for sunday drive and i'm stuck in office working.hehe.
anyway if u r still with stock internals, keep the boost low.tune it properly and do frequent oil change.as for others must wait for the sifus to comment.
turbolover is offline   Reply With Quote
Old 08-23-2009, 02:38 PM   #3
BLANk
BLANk's Avatar
Liked: 6,704 / 1,469 Posts
turbolover:today sunday still need to working!?....anyway,gambateh!!!
BLANk is offline   Reply With Quote
Old 08-23-2009, 03:17 PM   #4
turbolover
What to do if not no money to pump petrol.haha.want to change bigger turbo also so got to work harder.
Old 08-23-2009, 10:03 PM   #5
SkYwAlKeR
SkYwAlKeR's Avatar
Liked: 305 / 155 Posts
Send a message via MSN to SkYwAlKeR Send a message via Yahoo to SkYwAlKeR
Quote:
__________________
SkYwAlKeR is offline   Reply With Quote
The Following 5 Users Liked SkYwAlKeR For This Useful Post:
papagoines (10-02-2009), prasath_5338 (10-02-2009), SideWaysGrey (08-25-2009), spec-c (09-12-2009), turbolover (08-24-2009)
Old 08-23-2009, 10:31 PM   #6
xtremeleo
Liked: 461 / 324 Posts
take care of the oil, take care of the filter elements, just the basic stuffs
xtremeleo is offline   Reply With Quote
Old 08-24-2009, 07:52 AM   #7
turbolover
about air filters.i remember a few years back this guy with a silver top 4 throttle ask my mech about the power loss of his engine and when he opened up his hood,his open pod filter was so clogged up you cannot imagine.haha.either he drove in dirt road or his previous mech was an idiot.
Old 08-24-2009, 09:23 AM   #8
leonl
leonl's Avatar
Liked: 80 / 49 Posts
Use good synthetic oil.
Change oil more frequently.
Use higher octane gasoline.
Thicker head gasket to lower compression a little (4age engines usually are high compression).
Also, turbo timer to cool the off the turbo and to have oil properly drained out of turbo.
Good luck.
leonl is offline   Reply With Quote
Old 08-25-2009, 08:40 AM   #9
zendengoh
zendengoh's Avatar
Liked: 0 / 0 Posts
Send a message via MSN to zendengoh
and the cooling system as well.
__________________
Zhapalang E-autoparts - Malaysia's leading online autoparts store
Email : zenden"@"zhapalang.com.my
website : Google™ search "Zhapalang"
FB Fans Page : search Zhapalang Motorsport in FB
contact : 016-3282268
zendengoh is offline   Reply With Quote
Old 08-25-2009, 11:14 AM   #10
EvolutionZ
EvolutionZ's Avatar
Liked: 1,453 / 640 Posts
melanz,
u fit it in what car?
__________________
Evolution within Revolution
EvolutionZ is offline   Reply With Quote
Old 09-12-2009, 02:43 AM   #11
pathfinder
Liked: 0 / 0 Posts
the basic 1 is using good quality engine oil. It's fine to use semi-synthetic, just make sure dont exceed 5000km. If u regularly high revving/high speed, this requires shorter oil change interval.
also make sure cooling system is tip top. (oil & water flow). Drain & refill water/coolant regualrly (i darin & refill coolant every 10,000km)
dont overboost
turbo timer is helpful if u dont have time to wait at least 30 seconds (for normal drive). I dont have timer because i have the time to wait
pathfinder is offline   Reply With Quote
Old 10-01-2009, 09:59 PM   #12
Ahmad K
5bhp Stock
Liked: 0 / 0 Posts
wow i'm really new to mods whats a turbo timer
Ahmad K is offline   Reply With Quote
Old 10-02-2009, 04:46 PM   #13
huakenny
LB Performance
huakenny's Avatar
Liked: 239 / 143 Posts
Send a message via MSN to huakenny
Quote:
a timer to shut down ur engine automatically based on ur preset time(manually set or auto), after u turn ur ignition off
__________________
Email:kennykenny83@live.com
sms: 016-8417327
huakenny is offline   Reply With Quote
Old 10-03-2009, 12:13 AM   #14
dlj9788
dlj9788's Avatar
Liked: 0 / 0 Posts
Basicly, The Engine Oil Is The First Thing u need to see, what grade u using ? hv u upgrade anything to ur engine beside turbo ? hv u change the piston ? hi or low compression ? dun boost too high if ur piston compression is hi, exp (13.1 > up) hv u change ur ecu cause original ecu will hv the limit and will lock the fuel when reach the limit. add fuel regulator . must hv oil press and oil temp meter with u. that`s my opinion, but the main thing is ur engine oil, becareful not to rev high and remember to change oil whenever its dirty already. scare the conrod bearing will damage.
dlj9788 is offline   Reply With Quote
Old 10-03-2009, 04:21 PM   #15
dawg
dawg's Avatar
Liked: 47 / 27 Posts
make sure u install an oil temp and oil pressure gauge...
i prefer to cooldown my engine base on looking at my oil temp gauge compared to using a turbotimer to wait 30sec-1min just to cooldown... with the oil temp, u know how hot the oil is. normal driving should be 85-95deg for oil temp. if between 110-120deg ease off and cooldown the oil..
after hard runs, and ure engine oil is say 120deg... the turbotimer running for 2 mins also will not cooldown the oil to 95deg. u need to drive slow and let the air run thru your oil coolers etc to allow cooldown of the oil back to operating temps...
dawg is offline   Reply With Quote
The Following 2 Users Liked dawg For This Useful Post:
Alvin Lee Edwards (08-16-2010), har1th7 (12-16-2009)
Reply
Previous: Previous Thread | Next Thread :Next
Search this Thread:
Advanced Search
Display Modes
SEARCH
Our YouTube Videos
2000 - 2018 Zerotohundred.com - The Automotive Enthusiasts' Network | Tags | Terms of Use | Visitor Agreement | Privacy Policy | Contact Us | Privacy Statement | Top
