LSD & Full Lock? - Zerotohundred.com
Zerotohundred.com
HOME FEATURES NEWS FORUMS THE MARKETPLACE TIMETOATTACK!
Go Back   Zerotohundred.com > Car Discussions > Car Modification
Reply
Tools Search this Thread Display Modes
Old 05-02-2009, 05:50 PM   #1
WiiR4
150bhp Tuned Member
Liked 1 Time in 1 Post
Default LSD & Full Lock?
Hi! guys!!!
just want to ask bout' what is a difference between LSD Gearbox & Full Lock Gearbox coz' I'm lookin' an Evo3 g/b, I goes to some chop shop n ask for g/b, I said I want a it wit LSD but the guys said it is a non LSD g/b but it can be Lock to 2 wheel, I'm quite confused here , is it mean that from 4wd lock to 2wd or from non LSD to LSD, some of the thread in the internet (not only ZTH) also wrote the same "Evo3 g/b for sale, non LSD but can Lock to 2wd" I know some of my fren' done a non LSD g/b n weld the g/b to lock it so it work just like Full LSD (2 way), is it that what they mean? confuse here, n one more think if I done like some of my fren' weld the g/b, is it ok for long terms use or better use original LSD? last not least, I'm using Evo2 g/b non LSD is it a way if I just try to find just the LSD n plug it to my g/b even my fren' said it is very hard to find coz' usually they sell it 1 set with the g/b...anyone/any sifoo out there could help me PLEASE!!!
WiiR4 is offline   Reply With Quote
The Following User Likes WiiR4 For This Useful Post:
puklau (03-23-2013)
Old 05-02-2009, 09:24 PM   #2
jinkl
jinkl's Avatar
Liked: 379 / 155 Posts
Default Re: LSD & Full Lock?
Quote:
Originally Posted by WiiR4 View Post
Hi! guys!!!
huhuhu ok ok here it goes
gearbox that comes from an evo is a 4wd system
you have to lock it to 2wd to use in ur wira
you cant lock from non lsd to lsd just like that
u need to buy an lsd from the shop n fit it inside
the welding and making into full lock is a cheaper way
bt i dont recommend that if you are using ur car daily
brand new lsd can fetch 3k-4k
2nd hands are hard to find
its cheaper for you to sell your GB for a cheap price and
get a LSD gearbox from the chop shop
LSD gb frm chop shop should range 1.5k-1.8k
__________________
jinkl is offline   Reply With Quote
Old 05-02-2009, 09:53 PM   #3
n/a_tune
n/a_tune's Avatar
Liked: 0 / 0 Posts
Send a message via Yahoo to n/a_tune
what about different full lock? semi lock, 1 way, 1.5.and 2way lsd????
n/a_tune is offline   Reply With Quote
Old 05-03-2009, 05:03 PM   #4
WiiR4
150bhp Tuned Member
OOooo...I see, thax bro
Quote:
hmm...bout that not really2 know but from what I know is 2 way LSD is full Lock, mean that even if jack ur' car n spin the tires at one side the other side also spin, 1.5 LSD also quite the same but The LSD will working if both of the tires at the same equal pressure, & 1 way LSD is only working if ur car on the road, if ur' jack ur car & spin the tires the others not spin, from what I know laaa...pls correct me if I'm wrong...
Old 05-03-2009, 08:28 PM   #5
Zeroed
Liked: 45 / 16 Posts
Thats totally inaccurate la bro.
1-way LSD means the limited slip effect comes in only during acceleration, when you release the gas pedal it will act like an open diff.
1.5-way means it comes in full effect during acceleration, and only partially during deceleration.
2-way LSDs have full effect during both acceleration and deceleration.
Then there is the strength level of the LSD. Full-lock LSDs are basically high initial torque LSDs (depending on how people interpret the term "full-lock" also, but in malaysia as long as the LSD goes clank clank clank people say its full lock so...). Meaning the Limited Slip effect is there at all times, while milder LSDs only gradually build up the limited slip effect when the wheels spin unequally (slow reaction).
There are 1, 1.5, and 2-way full-lock LSDs as well.
The jacking up the wheel test doesnt work all the time, as different LSDs react differently. Normal Mitsu LSDs are clutch type, so you can just jack up the car and spin one wheel and see if the other wheel spins.
Honda Type-Rs have helical/torsen LSDs, this design wont spin the other wheel when you jack the car up unless you engage first gear.
Fluid type LSDs act differently depending on their design as well.
Welded diffs cannot pakai one. Only for drifting purposes. Not even track racing, unless you want to crash to a wall.
Zeroed is offline   Reply With Quote
The Following 7 Users Liked Zeroed For This Useful Post:
BadBlakie9136 (08-29-2012), EvolutionZ (05-05-2009), Neyo (05-04-2009), pangyau (03-24-2013), Streetjamer (08-07-2013), Wira_lover (05-09-2009), yeehau86 (01-04-2015)
Old 05-03-2009, 09:13 PM   #6
jinkl
jinkl's Avatar
if nt mistaken, mitsu evo's front diff comes with viscous lsd
nice info bro :)
__________________
Old 05-03-2009, 11:11 PM   #7
WiiR4
150bhp Tuned Member
learn 1 more thing today...thax!
Old 05-04-2009, 12:28 PM   #8
Neyo
Neyo's Avatar
Liked: 2 / 2 Posts
bro zeroed,jz a quick question,4 mitsu LSD's u sd dat u can jz jack up de car n spin 1 wheel 2 c if de other 1 follows suit or not.wat if it doesn't.does it means theres no LSD?any other way in determining whether de car is equipped wit LSD without having 2 open up de gbox?sorry if dis q is inappropriate here but i need 2 knw coz my mech said dat my engine came LSD equipped n when they chgd de gbox oil they used LSD type oil.However when i jacked de car up n spin 1 tyre,de other stays stagnant.thx in advance
Neyo is offline   Reply With Quote
Old 05-04-2009, 01:15 PM   #9
civic EdGe
civic EdGe's Avatar
Liked: 8 / 4 Posts
Totally agree with Zeroed.... My fren's old nissan uses the welding method to lock up both rear wheels just for the sole purpose of making donuts only..... his car really skids easily, maybe becoz both the rear wheels are forced to travel the same distance all the time.....
Btw, does Honda uses helical/torsen LSDs for their non type-R gearbox too? Torsen LSDs are more resistant to wearing out compared to LSD inserts rite?
civic EdGe is offline   Reply With Quote
Old 05-05-2009, 01:11 AM   #10
Zeroed
Im not sure about the newer mitsus, but the evo3 front LSD is also a clutch type I thought? I believe a mivec one is a clutch type atleast since ive seen it before...
Neyo, the easiest way to confirm is to remove a driveshaft and shine a light inside to see if there's a middle LSD shaft (or if its a viscous diff, a blocked housing) in the middle of the diff. Or remove both driveshafts and see if you can see through the hole. If you cannot, its likely that you have an LSD.
Sometimes you cannot feel the LSD effect due to a worn out LSD, but if the wheels dont even spin when you jack them up... then its unlikely that you have a clutch type LSD, or one at all in your gearbox lor. Another way is to put one wheel on an oily+wet surface and dump clutch & launch, and see if there's any power on the other wheel to move the car forward or not. You can put a small stone to block the wheel that is not on the oil+water to stop the car moving from the small transmission frictions, so if it moves its really from the power transferred by the LSD. But its still not an accurate test lah.
Civic edge, for non-TypeRs I believe Honda used viscous LSDs for their B series range. Torsen/Helical LSDs basically last forever, unless they are subject to big amounts of abuse like high horsepower wheelspins. LSD inserts i dunno la. :)
The Following 2 Users Liked Zeroed For This Useful Post:
civic EdGe (05-05-2009), Neyo (05-05-2009)
Old 05-05-2009, 02:01 AM   #11
jinkl
jinkl's Avatar
u may see
the evo I,II,III has an option of front LSD which is a viscous LSD
comes with longer crown wheel and a special longer driveshaft
know this well cos i play 4g63's
the mivec oem lsd is also a viscous lsd and later replaced with helical lsd
according to http://www.mivec.co.nz
__________________
Old 05-05-2009, 02:13 PM   #12
Zeroed
Ah. perhaps I saw an aftermarket mivec one then.
The only proton/mitsu LSD I ever used was a Cusco one so I dunno bout stocks.
Old 05-05-2009, 02:27 PM   #13
Neyo
Neyo's Avatar
Liked: 2 / 2 Posts
appreciate de prompt feedback guys especially zeroed.de main reason im asking is bcoz im due 4 a gbox oil chg very soon n if it doesnt hv an LSD then i can opt 4 de normal gbox oil instead which is cheaper.FYI engine is a CM5A GSR 1.8 which is de later model GSR with reverse timing belt placement similar to evo4 n above.but 2 b safe id better check if it really is an LSD equipped gbox first b4 changing oils as i wudnt want 2 damage it by putting in de wrong type of oil..cheers
Old 03-23-2013, 11:00 PM   #14
puklau
1bhp Stock
Liked: 0 / 0 Posts
hello bro,
i got evo 3 full lock g/box.
if i drive my gearbox is sound knock...knock...knock n sometimes my car can force go to left or right since i change the gearbox. my previous g/box is semi was totally damages. If i drive straight using 1st, 2nd for first movement my drive shaft also like loose.
are this all its bcoz 1) i use normal transmission oil n solution is i need change to kaaz/q8 lsd oil.
2) i use OEM right drive shaft n is the solution i need to change the long one (as i Heard)
pm the best solution Bro
puklau is offline   Reply With Quote
Reply
Previous: Previous Thread | Next Thread :Next
Search this Thread:
Advanced Search
Display Modes
SEARCH
Our YouTube Videos
2000 - 2018 Zerotohundred.com - The Automotive Enthusiasts' Network | Tags | Terms of Use | Visitor Agreement | Privacy Policy | Contact Us | Privacy Statement | Top
