extractor 4-1 and 4-2-1
malster
32
hye...
anybody can tell me whats the different between this 2 extractor..
and which one is better for satria 1.3m
tiburonshrk
52
4-2-1 are more intended for low revs and mid range. This helps during city driving or when u need just the right kick to overtake.
4-1 are designed for higher rpm range. I don't think this is appropriate as you don't usually rev ur engine that high most of the time.
Anyway, I don't think it is wise to change the extractor. A wrong design custom extractor will cause lots of problem to you such as loss of power. It is vital that an extractor measured and bent properly. If you still insist on changing, I would recommend hot bits extractor as I previously had on my satria and it was good.
malster
32
where can i find those r3 or hot bits extractor
tiburonshrk
52
For hot bits extractor, you can start with speedworks at jalan 222, PJ. They carry the whole range of hotbits products
malster
32
any1 noe where can find extractor yg murah2 punya:biggrin:
afmarsyal
100
6
wei yip wangsa maju atau seri kembangan..aku buat extractor kat diorang..4-2-1 downpipe swirl dalam rm280
malster
32
ooo murah gak..
kat seri kembangan tuh kat area mane
tamok
155
hallo guys
what about 4-4-1...lg power kot....cuma rege x leh tahan....
Hi guys and hear my story out.*
Need your opinion. After a bunch of other upgrades i decided it was time to mod my suspension.*
My car is a proton inspira btw.*
Initially 10 months back i started to change the spring to proton R3 springs. It was great, good compromise between comfort and handling. (level was 3 fingers loose back and 2 1/2 finger front)*
After a while my driving improved and started to feel that the suspension could not handle fast corners.*
Thats when i change my...
