full lock lsd - Zerotohundred.com
Zerotohundred.com
HOME FEATURES NEWS FORUMS THE MARKETPLACE TIMETOATTACK!
Go Back   Zerotohundred.com > Car Discussions > Forced Induction & Engine Management
Reply
Tools Search this Thread Display Modes
Old 10-07-2008, 08:58 PM   #1
kariayam
Liked: 48 / 26 Posts
Default full lock lsd
is it normal for a full lock lsd to produce a hard 'kicking' sound when doing a low speed turn or corner?
how to tell if the lsd is already worn?
is there any other way to reduce the 'kicking' sound? (any recommended lsd gear oil that will reduce the noise?)
btw i'm using an aftermarket full lock lsd in an e3 gbox (when buying my e3 halfcut) since the drive shafts length are same as the standard evo driveshafts.
kariayam is offline   Reply With Quote
Old 10-07-2008, 09:33 PM   #2
opp61
opp61's Avatar
Liked: 6 / 3 Posts
Default Re: full lock lsd
Bud
Dont know bout you but my R33 has the cling--cling sound when I turn but it get softer after the oil heats up.
How bout yours?
__________________
Drove:
Nissan Sunny 130Y Extra
Wira 1.3/ 1.5/ GSR Turbo
Mitsubishi Lancer Evo 2
Nissan 180 SX
Wira 1.8
Civic EG6 Vtec
Satria GTI Turbo
BMW E39 M sport
Skyline R33 GTS
Suzuki Swift Sport
KE70 4AGE
Drive:
Polo GTI
Soarer JZZ30
I love my nasi lemak, roti canai and nasi goreng cina
opp61 is offline   Reply With Quote
Old 10-07-2008, 10:37 PM   #3
kariayam
does the sound of yours 'knocks' hard when u do a turn at low speed?
mine always producing the kicking sound and knocks at low speed turns and never get 'softer' even the oil heats up.
however, if applying a full or high enough throttle, the lsd will 'lock" both drive shafts and no sounds or kicking at all.
ur r33 full lock lsd installed at the gearbox in front or at the rear differential?
thnks 4 sharing by th way...
Old 10-08-2008, 01:55 AM   #4
renxun
renxun's Avatar
Liked: 38 / 23 Posts
Send a message via MSN to renxun
my kaaz lsd produced same sound... knocking ... gets worst when oil heats up... the only way i bring the noise down is to use Lubeguard lsd treatment.... the one like toothpaste... it helped quite alot... however after seriously heated up it still clunk.... or maybe u should adjust your way of driving like throttle off during slow turn and give gas only when your car is straight...
renxun is offline   Reply With Quote
Old 10-08-2008, 03:37 AM   #5
jinkl
jinkl's Avatar
Liked: 379 / 155 Posts
i tink its normal la bro , im using a fwd full lock , hehehe, i frequently change my oil , gl-5 SAE :D , penzoil works for me, quiet :D
__________________
jinkl is offline   Reply With Quote
Old 10-08-2008, 05:04 AM   #6
kroolada
kroolada's Avatar
Liked: 2 / 2 Posts
try used motul gear oil ff-lsd type 2. i used it at my evo gearbox with full lock lsd , no noise so far.
kroolada is offline   Reply With Quote
Old 10-11-2008, 04:50 AM   #7
raja_emeperor
raja_emeperor's Avatar
Liked: 28 / 15 Posts
agreed with jinkl, penzoil are the best!cheap and good stuff.
__________________
raja_emeperor is offline   Reply With Quote
Old 10-11-2008, 08:27 AM   #8
renxun
renxun's Avatar
if cant find penzoil... can go get toyota lsd oil.. they are penzoil too....repacked by toyota to become oem product
Old 10-11-2008, 11:24 AM   #9
kariayam
Quote:
ooo thanks!!! i'm using the toyota lsd oil...never knew it is a penzoil too..
Old 10-13-2008, 10:12 AM   #10
pijulrs
pijulrs's Avatar
Liked: 16 / 12 Posts
Hi all,
I got some question to ask.What is the simple way to know the difference between full lock lsd and half lock lsd for 4g63 gearbox?im using gearbox series number W5M322-WQNK.Is it got lsd?
__________________
sss-l-e-e-kkk psttt
pijulrs is offline   Reply With Quote
Old 11-02-2008, 10:54 PM   #11
proPIPING
proPIPING's Avatar
Liked: 5 / 4 Posts
Quote:
Originally Posted by pijulrs View Post
Hi all,
put da front of da car on jack or stand to keep da front wheel hanging,rotate one side of the wheel,if the other side rotate same direction ask u rotate,your g.box have lsd in it....
proPIPING is offline   Reply With Quote
Old 11-03-2008, 04:15 PM   #12
Trinityblood
Trinityblood's Avatar
Liked: 21 / 17 Posts
Quote:
yes...juz like chop shop doing all the time.hehe
__________________
Trinityblood is offline   Reply With Quote
Old 11-12-2008, 02:54 PM   #13
momosyah
Liked: 0 / 0 Posts
My car when turn about 20km/h the tuk,tuk,tuk sound will produce the sound.A bit shy when to turn at residential area.But very best when running.
momosyah is offline   Reply With Quote
Old 11-13-2008, 08:26 PM   #14
proPIPING
proPIPING's Avatar
Liked: 5 / 4 Posts
Quote:
always running laa like that...don't ever slow down hahaha
Old 11-14-2008, 12:28 AM   #15
tandem
100bhp Junior
tandem's Avatar
Liked 1 Time in 1 Post
hi sifus i have 1 question about lsd... if normal mivec gb can can add lsd??
tandem is offline   Reply With Quote
Reply
Previous: Previous Thread | Next Thread :Next
Search this Thread:
Advanced Search
Display Modes
SEARCH
Our YouTube Videos
2000 - 2018 Zerotohundred.com - The Automotive Enthusiasts' Network | Tags | Terms of Use | Visitor Agreement | Privacy Policy | Contact Us | Privacy Statement | Top
