How to DIY for Waja 1.6 4G18 Throttle body cleaning - Zerotohundred.com
Zerotohundred.com
HOME FEATURES NEWS FORUMS THE MARKETPLACE TIMETOATTACK!
Go Back   Zerotohundred.com > Car Discussions > Do-It-Yourself Garage
Reply
Tools Search this Thread Display Modes
Old 06-29-2008, 05:47 PM   #1
lamer2000
5bhp Stock
Liked: 0 / 0 Posts
Default How to DIY for Waja 1.6 4G18 Throttle body cleaning
Can anyone with experience here show us the way to DIY waja 1.6 4G18 Throttle body cleaning.My waja is giving me alot of problem and I suspect its due to a dirty throttle body.I read similar cases where the problem was solved by cleaning the throttle body so I was thinking of doing it myself to save cost.
Hopefully someone can provide us a step by step guide together with pictures.Thanks ya
lamer2000 is offline   Reply With Quote
Old 09-15-2008, 01:33 AM   #2
Ellipse506
Liked: 5 / 2 Posts
Default Re: How to DIY for Waja 1.6 4G18 Throttle body cleaning
My suggestion is to get it done at the workshop and get it re-tuned with the MUT/PDT2000 after that...
If you want to DIY, just remove all the hoses, remove the 4 main screws bolting the TB to the intake manifold.
Then use petrol/diesel with a brush to remove the excess dirt deposits on the butterfly plate and inner parts... Be sure not to wet the sensors, if you are confident enough with a voltmeter, you can remove the stepper motor and after you clean it, you need to get a certain voltage to make sure u got the right step or else ur tuning kong like s**t... My suggestion is to leave it and just be careful when cleaning it... most workshops do that anyway...
Remove the idle screw and clean that as well... then replace it till the end and loosen it about 8-10 twists...
when you place everything back (be sure not to overtighten or you'll screw up the bolt's teeth), then start the car, and tune the idle screw till you get to about 750-800rpm, or whatever you like as an idle la... 900rpm is a nice one to have as you get to start off the traffic lights nicely (if you are using AT)...
hope this helps...
Ellipse506 is offline   Reply With Quote
The Following 4 Users Liked Ellipse506 For This Useful Post:
Altec90 (03-29-2009), kimsiow79 (07-01-2009), Shanashi (09-15-2008), warrewolf (09-18-2008)
Reply
Previous: Previous Thread | Next Thread :Next
Search this Thread:
Advanced Search
Display Modes
SEARCH
Our YouTube Videos
2000 - 2018 Zerotohundred.com - The Automotive Enthusiasts' Network | Tags | Terms of Use | Visitor Agreement | Privacy Policy | Contact Us | Privacy Statement | Top
