kenari aircon/performance
t3rry
7
Hi brudder,
i encountering the air con not cool if encounter in jam, & how to inprove on the a/c. by the way been seek this info, so will change bigger alternator, and compressor helps, what will be the setback.
another thing is, how do i improve the performance for kenari(auto), turbo? so can we just add on, approx how much, and been hearing L5/L9, is it refer to change engine.
thks, looking 4 expertise advise
DJgErM
4,014
118
3,163
SIC Turn 7 & 8
www.germ.cjb.net
bro,
yea L5 is from mira...aka like kancil....and L9 is move.....no matter RS(tiptronic), Aerodown, casual
yes and that means you have to undergo a transplant..
since there are some good choices of 1.3 engines ? y downgrade?
althought L9 has the 3 cyl and 4 cyl turbo...but it is still a 660 capacity engine..
and big alternators are not supposingly 100 % good if used in your current engine..
for autotranny, there are several things that u can do to optimize some juice out of it... for instance, using better auto transmission oil like redline...and some DIYs..
And last but not least, a good maintenance..
Tohsan
Over 10,000 RPM!
17,882
51
Char Kuoy Teow
t3rry
maybe u want to try like what i do to my kenari,change to bigger aircond compressor from Suzuki. Accessories shop will know how to do for u. Btw the pickup will drop a lil bit but it will be so much more cooler during hot day.
mag9556
2,770
43
1,648
There is piston compressor for Kancil, Kelisa and Kenari nowday.. No need to use Vitara compressor liao...
Good Luck...
mag9556
2,770
43
1,648
Normally compressor have 2 type..
Rotary that is use on K-class car and some honda cars..
Piston type that like those wira car ( denso type )..
Tohsan taiko....you are using vitara compressor right.. that's piston type that will pull the car..hehehe..
Now they have recond version of K-class car (aftermarket one) just 300 bucks only... but dun know from what car..just claim that fit K-class car only....
The RPM wise.. not sure but confirm car will lost a bit of power...As Tohsan taiko said...
BV5015
2,001
JB
by changing bigger rpm, will take risk of water leaking -_-...
coz the piping not suffecient for the air travel in it....
t3rry
7
Thank a brudder for all your expertise advise..
Stretching the meaning of the word ‘used’ to its most technical limits, Japanese used car auctioneer Aucnet has sold a barely-driven GT-R at auction. The pearl-white Premium Edition GT-R sold for 10.4 million Japanese yen (USD=JY111) on December 10th, which works out to roughly US$94,000 or €63,945 - about US$25,000 over the base MSRP of $69,850.
Although the GT-R’s mileage is unknown, mileage was probably close to 0...
