Proton 1.6 Flywheel help!!
jee_square
240
Taman Melawati
Guys, really need help here...
Can a 4G92P engine be fitted with a 4G13P flywheel?
Im converting my engine, my mech says i gotta change flywheel coz the 1.6 flywheel is cracked.. I'm thinking of saving money so i wanna use back the 1.3 flywheel.. Is this possible? My mech says no, but i just wanna confirm..
Glad for ur help guys!
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
1.6 flywheel is bigger compare to 1.3 flywheel rite??...
if 1.3 wanna fit 1.6 flywheel, need to mod the flywheel by skimming it.... but if 1.6 wanna fit 1.3 flywheel not vr sure... try go halfcut shop ask them let u compare 1.6 and 1.3 flywheel and see the difference...
dino1711
148
1.6 flywheel have 7 screw,
1.3 flywheel have 5 screw,
oso the clutch size is different,
1.6=8'. 1.3=7.5'
for sure cannot use.
thanks
sn_ting
104
snting.blogspot.com
if u used back 1.3 clutch kit. u will experience clutch slip and ur car will lost power. i suggest u used 1.6 clutch kit and lighten the flywheel...
sn_ting
104
snting.blogspot.com
btw i got one clucth cover and one flywheel for wira 1.5 GLi ready to let go ....interested?
AmuroRay
736
emm...... maybe u can check with brian...... his stuff price quite okay.....:_:
http://www.zerotohundred.com/newforums/showthread.php?t=83511
Do i need to change the spring to adjust the front high low so called adjustable suspension ?
Its on a Kenari with a 2.8kg spring (on pervious owner) and now put into my kenari it was too low til it hit my fender and bumper was gliding thru bump.
so i went back to titan and ask them to make the front higher, titan boss mr.richard say have to put in a spacer in the spring and adjust it higher.... he say that is the most fastest and cheapest way. (but not safe lar, i think!)
another way ...
