Airtrek Turbo subframe
biao
348
24
518
perak / ipoh
Hi All Sifu,
i have something need to ask and know about our Airtrek subframe (front) & (rear).
Our front subframe if want to convert to EVO, version 7 to 9 is can fix, right? if only take the EVO lower arm to fix on our original subframe, can?
did any sifu have convert the rear subframe, camber and lower arm to EVO type? if can convert, which version compatible?
stutzedward
3,416
561
I heard from Ah Wah previously that front subframe + steering rod can be installed in Airtrek improving steering response drastically. I am not sure about the rear tho.
biao
348
24
518
perak / ipoh
ya, the front can. but is it from evo 7-9 also compatible?
4gbanger
Jun 26, 2013
1,958
386
683
Johor/ShahAlam
front subframe from evo 789 can be fit provide complete with steering rack and driveshaft. rear im not sure as evo has AYC then need to wired the all the electronic system.. if u need LSD, just get the diff internal only and transfer to our rear diff.
biao
348
24
518
perak / ipoh
if just convert all the arm only without subframe, can?
because i saw the evo arm look more solid than ours airtrek.
Hi all DIYers@zth
4-5 months ago, i did some searching and finally found a guide to make this.
(Buying a Bee-R launch was out of budget.....)
My purpose was to make a DIY Launch Controller ... however since the rpm signal is adjustable,
you can trigger a 12v relay for any purpose...from cutting ignition, fuel, on sub injector, on mivec, on horn, on central locking system and etc at what ever rpm you want.
example....
Set rpm adjustment to 6000rpm, once reach 8000= horn sound...or...
