[WTS] Silicon Coil Spring Insert/Isolator
fearless
1,945
Dear All,
I am selling silicon coil spring inserts/isolator for almost all cars and
model. This inserts/isolator which I am selling is make of sillicon and
NOT rubber unlike those selling in Brother Accesories shop. This sillicon
compound insert will last way longer than those rubber inserts.
The effect after installing these insert would be an improved in the ride
comfort, braking efficiency, would prolong shock absorber lifespan due to
less vigrous absorber shaft movement as its damped by these inserts.
Besides,it will also reduce vibration and noise. Its very suitable for
those car with soft suspension setting which often bottom out when going
over a huge speedbreaker.
Price for 4 pc of this insert/isolator is from RM 160 to RM 170 depanding
on your coil spring size.
For enquires please call or sms 012-2702478
Thanks
civic EH5 (local model)
just noticed my PS fluid are low and found out that my tie rod have leaks. what are possible solution?
p/s: i've replaced whole steering rack less than 2y ago
another question from pic below... do i need to replace bush? (outer tie rod)
