myvi 1.3 first gen cant accelerate above 120 km/h
sweelt
sweelt
Nov 6, 2016
2,306
248
663
Penang
check your engine, transmission, exhaust first. Don waste money yet on 6mt gearbox.
when i start driving daihatsu charade g11, 3 cylinder, 4mt only, can reach 110-120kmh. Stock engine.
6UE5t
6,000 RPM
6UE5t
6,000 RPM
6,756
1,300
Hi all can i ask if the above problem is due to gearbox problem or is there any other cause? Thank you in advance.
Can be gearbox and can be engine not in good condition anymore, not optimum power. What year and how many km already traveled on this car? Is it still in std condition or have done some mods or how?
Beyond 20,000 RPM!
Beyond 20,000 RPM!
29,998
Sometimes cars not run in properly will have less power to achieve top speed......
Triple Y
Triple Y
37
year 07 mileage about 150k , tested the car when stock . just done major service and change the extractor, bullet, catalytic, n sflow, some bars. still abit hard to cross 120km/h.
Triple Y
Triple Y
37
6mt on myvi got i saw a post at zth that one myvi owner use 6 speed gear from ae111 blacktop 6 speed then use back the ori housing.
6UE5t
6,000 RPM
6UE5t
6,000 RPM
6,756
1,300
Maybe need to do carbon cleaning to clean up the fuel system, intake manifold, and combustion chamber. When servicing also should check your AFR, is it running too rich or lean. So this is a manual car also?
sweelt
sweelt
Nov 6, 2016
2,306
248
663
Penang
you do major works on exhaust system itself. If Engine cant breath properly, car performance affected.
What major service you've done, btw.
What sort of exhaust work did you do? 120 is pretty impossibly low.
Triple Y
Triple Y
37
engine oil, gearbox oil, throttle bodycleaner , fuel injection n valve cleaner, ori air filter, iridium spark plug all done when doing major service n mine is auto
Triple Y
Triple Y
37
i done major exhaust changing because when i get the car the car rpm cant go smoothly a bit laggy. i think the stock exhaust is stuck n extractor gasket was worn out.
Triple Y
Triple Y
37
4-1 extractor (alloy) , hi-flow catalytic and swirl bullet (kent wong exhaust) , custom s-flow (jian hang)
still using stock exhaust pipe will it be the cause of stock exhaust size
^pomen_GTR^
7,000 RPM
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
not gearbox problem...
its either your engine not running properly....
or u expect myvi got some tebo power to accelerate over 140 easily
i now use original VR4 wiring i think i will change it because have many problem ,i think i will change to evo 3 wiring but i scary that will have the same problem like engine just shut off.. ... timing no like shit... so what do i need to do....
