SuperPro PU Bushes! improves your handling immediately!
ninja_iga
3,376
hi guys
PLEASE call Chris 012-377-2323
as i'm no longer doing SuperPro :)
WHY SUPERPRO?
SuperPro is a polyurethane elastomer based material and is a class of "Thermosetting" synthetic polymer that involves the reaction of various types of isocyanate resin with curing agents to give an extremely durable material with the best features of rubbber and plastic.
the range of cars i've got stock of:
Proton
a complete set for Proton Wira/Satria/Putra/Waja/GTi consists of:
FRONT
control arm lower (lower arm)
front bush RM140
rear bush RM180 (or get the anti lift kit with maximum caster, RM210)
steering rack mount bush RM120
ARB link bush kit RM80 (RM10 each)
ARB mount to chassis bush RM65 (different ARB diameters available)
REAR
lower arm, inner & outer bush RM380
upper arm inner bush RM650
lateral arm front outer RM650
lateral arm inner RM160
ARB link bush kit RM40 (RM10/each 4pcs)
trailing arm front bush RM320
please note that this is not a comprehensive complete bushes replacement list. Some bushes may not be available in this list and must be replaced by OE rubber bushes.
Mitsubishi
Evo 3-8
FTO
Galant HJ 1993-96
Front
lower arm inner bush RM130
upper arm inner bush RM130
ARB mount to chassis bush RM50
REAR
upper arm outer bush RM150
ARB chassis mount bush RM50
AlfaRomeo
164
BMW
BMW E36 3series
FRONT
-lower arm rear bush (standard setting) RM235
-lower arm rear bush (increased caster) RM435
-ARB mount to chassis bush (check size!) RM105
REAR
-control lower arm front bush RM315
-ARB mount to chassis bush RM55 (check size!)
Ford
Laser TX3 KF-KH 1990-94
Honda
CRV 1997-2001
CRV 2001 onwards
Prelude BB2 1991-96
Integra DC5, TypeR
Civic ES
Civic EF complete set
Front
-lower arm, inner bush RM145 (please check size)
-upper arm, inner bush RM325
OR
-upper arm, inner bush(max camber, -1) RM440
-strut bar to chassis mount RM145
-ARB link bush kit RM195
-ARB mount to chassis kit (check size) RM60
REAR
-lower arm, inner & outer bush(pressed metal arm) RM285
OR
-lower arm, inner & outer bush(cast arm) RM240
-lateral arm front RM165
-lateral arm rear inner RM90
-lateral arm rear outer RM130
-ARB end bush RM128
-ARB link to lower arm RM110
-ARB mount to chassis bush RM50 (check ARB diameter)
-trailing arm lower, front bush RM280
Civic EG
FRONT
-lower arm inner front bush RM160 (check size)
-lower arm rear bush RM215
OR
-lower arm rear bush RM285 (increased caster)
-upper arm inner bush RM325
or
-upper arm inner bush RM440 (increased camber -1)
-ARB mount to chassis bush RM60 (check size)
REAR
lower arm, inner & outer bush RM240
-trailing arm lower- front bush RM280
Civic EK
front
-lower arm inner rear bush RM340
OR
-lower arm inner rear bush (increased caster) RM350
REAR
trailing arm lower front bush RM280
Integra DC2 TypeR
FRONT
-lower arm inner front bush RM145
-lower arm rear bush (standard caster) RM215
or
-lower arm rear bush (increased caster) RM285
-lower arm upper inner bush RM325
or
-lower arm upper inner bush(more camber)RM440
REAR
-lateral arm front (inner and outer bushes) RM165
Civic ES 1.7
FRONT:
-lower arm inner front and rear bush kit (increased castor) RM575
-ARB to chassis bush RM60
REAR:
-lower arm outer bush RM325
-upper arm outer bush RM155 (standard settings)
-upper arm outer bush RM220 (adjustable camber)
ARB to chassis bush RM50
Hyundai
Coupe FX 1996-1999Sonata EF 2003
Mazda
Mazda BF Series 1985-1989
FRONT
lower arm front bush RM165
-lower arm rear bush RM145 (increased caster)
-steering rack bush RM99 (manual steering)
-ARB link bush kit RM80
-ARB mount to chassis bush kit RM50
REAR
-trailing arm lower all bush RM185
Mazda 323, Astina BG 1989-1996
Front
-lower arm front bush RM105
-lower arm inner rear bush RM145
-ARB mount to chassis bush RM50 (check size)
Rear
-ARB mount to chassis kit RM50
-trailing arm front bush RM135
-trailing arm rear bush RM150
MX-5 1989-97
Nissan
Nissan 180sx / S13 1984-1994
FRONT
strut bar to chassis chassis mount (adjustable caster) RM330
-ARB link bush kit RM40
-ARB mount to chassis bush RM55 (check size)
REAR
lower arm -toe adjustment arm (2 wheel steering only) RM230
-upper arm -inner/outer bush RM230
-upper arm -inner/outer bush eccentric (inner &outer camber adjustment) RM445
-cross member supplement washers RM60 (check size)
-radius arm upper-inner/outer bush RM230
-ARB mount to chassis bush RM65 (check size)
Nissan 200sx, S14/S15
FRONT
strut bar to chassis mount "adjustable castor" RM330
ARB link bush RM40
REAR
upper arm inner / outer bush RM230
eccentric upper arm inner / outer bush RM445
cross member supplement washers RM50 (small ring)
cross member supplement washers RM60 (large ring)
Radius arm upper- inner/outer bush RM230
300ZX Z32 1989-96
Skyline R32 GTS, GTR
Skyline R33 GTS, GTR
Skyline R34 GTS, GTR
Subaru
Forester SF Turbo 1997-2000
Legacy Turbo 1994-1999
WRX GC, STi 1993-2000
Subaru WRX GDB, STi, MY01,02,03
FRONT
-lower arm front bush RM160
-lower arm rear bush RM440
OR
-lower arm rear bush RM440 (castor kit)
-steering rack mount bush RM105
-ARB mount to chassis bush RM75 (check diameter)
REAR
-lower arm inner & outer bush RM478
-cross member supplement washers RM80
-ARB link bush kit RM175
-ARB mount to chassis bush RM50 (check diameter)
-trailing arm lower front bush RM180
-trailing arm lower rear bush RM180
WRX, STi, MY04
Toyota
Toyota AE86 Front
lower arm bush RM95
-strut bar to chassis mount RM88
REAR
-Panhard Rod bush kit RM55
-Panhard Rod to chassis mount RM66
-Panhard Rod to diff mount RM55
-ARB link lower bush RM65
-ARB link upper bush RM40
-trailing arm lower ALL bush RM280
-trailing arm upper ALL bush RM280
Toyota Corolla AE101-111 1994-1999
FRONT
-lower arm inner front bush RM100
-lower arm rear bush RM405
-ARB mount to chassis bush RM55 (check ARB size)
REAR
-control arm bush kit RM428
-trailing arm arm bush kit RM210
for more info:
SuperPro Poly Bushings
ninja_iga
3,376
Price List
FRONT
front bush RM125
rear bush RM160 (or get the anti lift kit with maximum caster, RM190)
steering rack mount bush RM100
ARB mount to chassis bush RM50 (different ARB diameters available)
REAR
trailing arm front bush RM299
mikeeeee
36
Penang
dude,
can you quote me for mx5 bushing ... some of mine bushing kaput oledi ..
how long lead time you need ?
Aura
1,942
5,138
Please quote me a full set of bush for Daihatsu Charade Aura G100 including the power steering rack and the price as well... Thank you..
mikeeeee
36
Penang
Front
SPF1987K
SPF0615-_ _K (i dont have the measurement with me)
Rear
SPF1987K
SPF0722-_ _K (i dont have the measurement with me)
does the measurement affect the pricing of the bushes ??
ninja_iga
3,376
sorry mate, no daihatsu parts here :(
mikeeeee
front:
sway bar link bush kit : Rm184 (also known as Anti-roll-bar)
sway bar mount to chassis kit : RM50 (same price for difference ARB sizes)
rear:
RM 185
RM55 (same)
mikeeeee
36
Penang
thats for both left and right, correct ??
thanks for your quick response ...
will keep your prices in mind ..
do u have ready stock or need to order ??
Fellow veterans,
Recently very itchy wanna mod my 07' LMST to provide better driving experience. Hehe.
I need some suggestions as I know nothing about modding cars and am totally virgin in car technicals! Since this car is built on low quality, I dont think I want to put too much cash in it. Gonna just stick to the cheapest. So, no turbo and high-end mods for me =P
I want to mod the car to be more fun, not just to be faster. Fun would be more important hehe. And I'm into taking...
