TEVO Creations Automotive Full Range Glass Coating
Car Shops and Services
th3ng
15
1,503
ABOUT US
Leading Protection Coating Manufacturer & Supplier
TEVO Creations provides integrated technology solutions worldwide, associating with high quality and innovation products specialized in the field of chemistry, engineering and nanotechnology. Together with leading R&D professionals; we develop, design, enhance and market highly innovative products ranging from electronics, household consumers to industrial users with the aims of provide one stop, end to end services for all individuals, companies and business associates. Our business is segmented into several key section:
PRIVATE LABELING
TEVO Creations offered a complete adaptive package for our client; we provide private labeling service for our client company in carrying our selected product in their own brand; by providing workable OEM MOQ (Minimum Order Quantity) and strong backend technical supports. Our experts will also be assisting conceptual design, art work, packaging and marketing guidance over our supplied products.
Car body wax or coating agents are necessary item in order to protect the clear coat and base color; whilst, TEVO has incorporated with our High Performance Automotive Coating series with inorganic glass compound. Importantly, our coating was produced with the adjustable amount of active ingredients, the higher percentage of active ingredients contained in the solution will resulting higher glossiness and longer durability of the coating itself.
Base color and clear coat are not strong enough against the ultra violet rays, acid rains, scratches or stains. The surface will be easily faded if the wax wasnít reapply constantly, worst scenario ending up collection of rust spots.
Our Glass Coating Product series will protect the clear coat and base color from ultra violet rays and acid rains, preventing them from degradation and color fading. It enabled the painted surface look as glossy as a new car even 5 years later. Besides that, stains would be hardly get stuck on the surface due to the super hydrophobicity of the coated surface, even it is stained, it can be easily removed by plain water flushing and rinsing.
Demostration & Commercial Video:
https://www.youtube.com/watch?v=YJ4pvrzAxXs
https://www.youtube.com/watch?v=N1-GHo84IYY
TEVO Creations Products Range
CAR BODY PROTECTION COATING
Unipell (Casual)
Unipell can be applied after every car wash on wet-to-wet conditions. Just spray on the wet surface and leave it for few minutes before rinsing off, it will leaves a thin layer of protection coating that provides you immediate hydrophobic (water beading) effect and paint protection.
UniGard-S06 (Casual)
UniGard-S06 can be applied on any surface of your automotive (except seats & cushions), finishes and protects the surface with exceptional glossiness & water beading effects. Single layer of coat will be able last up to 12 months, and can be applied continuously generating multiple coats to patch up the surface!
LINK: Automotive - UniGard S06 id=31
BodyGard-S36 (Water Based - VOC Free)
VOC Free Premium Glass Coating for painted automotive body. BodyGard-S36 is non-toxic & low solvent composition. BodyGard-S36 will not deteriorate with weather nor ultraviolet rays. Guaranteed no more waxing for the next 3 years.
LINK: Automotive - BodyGardS36 id=33
BodyGard-S60 (Premium)
Premium Glass Coating for your automotive body. BodyGard-S60 is formulated with highest standards of solution which protects your paint work with ultra-firm glass filming that not even a small blemish can adhere to the surface easily. BodyGard-S60 will not deteriorate on weather condition nor ultraviolet rays. Guaranteed no more waxing for the next 5 years !
LINK: Automotive - Bodygard S60 id=34
BodyScrub (Pre-Coat Preparation)
Mild acidic based car body cleaner that works like clay. It helps to remove iron and dirt particles that is deeply adhered to your car body surface easily. Best to be use before applying coating.
LINK: Automotive - BodySrub id=35
pH Neutral Shampoo (Post-Coat Maintenance Wash)
Water marks, bug stains, scales, etc. can be resolved and easily removed. Soak the product with a cloth or sponge, scrub the area for few times, and rinse off with plenty of water.
GLASS PANEL PRODUCTS
GlassGard
Nanoscale & durable invisible coating creating super hydrophobic (water beading) protecting coating on your glass panel. Significantly improves your visibility during driving in the rains, creating easy cleaning surface by preventing permanent stains to adhere onto your glass panel.
LINK: Automotive - GlassGard id=37
Ultra Watermark Remover
Our latest innovation! Used to remove stubborn watermark, scales & scratches from your glass surface. It can be done either by hand or polishing machines. Unlike conventional method (acid wash and sanding), first of its kind that easily remove your watermark & stains without hurting rubber or aluminum surfaces.
LINK: Automotive - UltraWatermarkRemover id=38
Glass Degreaser
Decompose tough oil, old coating in few seconds without using a polisher! It breaks down incurable scales, stains, and old grease quickly and easily, best to use as a quick preparation before window glass coating.
LINK: Automotive - Glass Degreaser id=39
PLASTIC, RUBBER & RESIN PRODUCTS (DASHBOAR/HEADLAMPS)
PlusGard
New formulation that use to be apply on plastic parts & faded parts. TEVO PlusGard helps to rejuvenate the color contrast and glossiness from your dull & faded surface. Enhanced characteristic of stain repellent and easy cleaning, retaining your color for more than a year.
LINK: Automotive - PlusGard id=36
METAL & CHROME PRODUCTS
MetalGard
Specially formulated for metal surfaces, usable on aluminum & stainless steel parts. TEVO MetalGard formed a hardness of 9H withstanding heats, brake dust and abrasions; protects coated surface from ageing, oxidization, rusting and avoid any permanent stain marks. Sustain chrome mirror glossy finishing up to 2 years.
LINK: Automotive - MetalGard id=40
MetalScrub
Special formulated abrasive scrub for metal and aluminum surfaces. Metal scrub helps to remove your oxidized metal surfaces and restore your metal surface with CHROME MIRROR finishing.
LINK: Automotive - MetalScrub id=41
NOTE
Now, we are looking for more dealers and car detailers ( locally and internationally ) to join TEVO Creations ! Please do not hesitate to contact us if you require more info.
CONTACT INFO
FACTORY ADDRESS
Plot 155, Jalan Perindustrian Bukit Minyak 7,
Bukit Minyak Industrial Estate,
MK 13, S.P.T. 14100 Bukit Mertajam, Penang, Malaysia
Phone:+6045085688 / +60124088077
Fax: +6045085680
E-mail: [email protected]
th3ng
15
1,503
TEVO Creations provides full range of advanced glass coating to protect your vehicle from surface deterioration and permanent stain issue !
TEVO BodyGard S36 helps to protect Ducati Superbike from ageing, UV, and stain problem.
TEVO Creations advanced glass coating provides mirror finishing and keeps your car/bike paint shines at all time.
TEVO BodyGard S36 helps to protect BMW GS from ageing, UV, and stain problem. BodyGard-S36 will not deteriorate with weather nor ultraviolet rays. Guaranteed no more waxing for the next 3 years.
The classic Mini Cooper S is now protected by TEVO BodyGard S36. It rejuvenates the paint, protects the paint and delivers mirror finishing surface.
th3ng
15
1,503
TEVO PlusGard will protect your automotive plastic surface color from fading !
Spot the before and after effect of TEVO PlusGard on the plastic surface !
The Aston Martin DB9 is now protected by full range of TEVO Glass Coating !
Performance luxury saloons are great, all that power wrapped in a highly desirable metal suit creates a certain appeal that checks all the right boxes. Almost. There is almost always room for improvement, that's why performance divisions and tuners exist. <!--more-->
