- Aug 31, 2008
- 1,143
- 22
- 1,638
TOYOTA VIOS 1 Stop Performance Center
Toyota Vios 03/07 performance parts
Engine Performance for Vios 03/07
NEW ARRIVAL
TOYOTA 1NZ-FE BLOCK GUARD
Custom Made by AZ Autoworks
C&C Cutting
Fully aluminium
RM1588
Toyota VIOS 07
AIR RAM PIPE with MAF Adaptor flange for Open Pod
RARE fully Custom Made
RM 280
NEW Denso 530cc Injector
High Impedance
Top Feed
RM988
actual photos
NEW Denso 650cc Injector
High Impedance
Top Feed
Product Code : 63562
RM1188
actual photos
Toyota Vios 03 Aluminium Radiator
Brand: Synergy
Full Aluminium
RM 550
actual photos
Custom Fuel Return System ( especially for BOT & Supercharger system )
RM 480 excluding fuel regulator
Toyota Vios 03 Automatic to Manual Conversion
Item comes with
1NZ FE 5 Speed Manual Gear Box
Gear Lever & Pedal set
Clutch Pump
RM4500 with installation ( Limited stock )
Performance Stainless Steel Extractor
Model : Standard Performance
Type : 4 x 1
RM 370
actual pics
Performance Full 100% Stainless Steel Extractor ( fully imported )
For High Rev
Type : 4 x 1
RM 550
actual Pics
High Performance Stainless Steel Extractor ( Locally custom made )
For High Rev and Smooth
Type : 4 x 1
RM 499
actual pics
Turbo Manifold
Toyota 1NZ FE Turbo Manifold Cast Iron with wastegate Flange
Type : T25 flange ( or T3/ T4 / DSM Mitsubishi )
for Vios 03/07 , Scion , Yaris , Vits , IST
RM 1500
Actual photos
ORIGINAL Denso Iridium Spark Plug
IK20/22/24 ( Vios ) : RM170 100% original or money back
Open Pod Filter Kit for Toyota Vios 03 & 07
Comes with
Open Pod Filter
Adapter
Silicon hose and Clamp
RM 170
Handling Performance
Brand New Adjustable for Toyota Vios 07
Hi - Lo adjustment
RM 1680 ( Cash and Carry )
Brand New Adjustable Absorboer for Vios 03-06
Hi - Lo adjustment
RM 1600 ( Cash and Carry )
1 Year Warranty
Ultra Racing
Bought more than 2 item - more discount hehe
For Toyota Vios 07
Fender bar - RM270
Front bar (2 Point) - RM160
RR bar - RM150
Room bar - RM 190
Antiroll bar 16mm - RM 450
antiroll bar 19mm - RM 550
Front Lower Bar - RM250
Middle Lower Bar - RM120
Rear Lower Bar - RM190
For Toyota Vios 03
Vios 03 Front Bar ( 2 Point ) - RM 180
Vios 03 Front Bar ( 4 Point ) - RM 240
Vios 03 Anti Roll Bar ( 19mm ) - RM 450
Vios 03 Anti Roll Bar ( 16mm) - RM 380
Vios 03 Lower Side Bar - RM 350
High Performance
Bot On Turbo Kit
For Toyota Vios 03 & 07
For Automatic Transmission ( softcore )
Item include
Cast Iron Turbo Manifold with Wastegate Flange
38mm Wastegate
Garrett T25 AR48 Turbo ( refurbish from Tong Turbo )
Blow Off Valve
Greddy E manage Blue
Extra Injector
Intercooler Kit
Expected horse Power 130WHP to 150WHP on auto transmission
Boost at 0.6Bar
With installation and dyno tune
RM 9000 ( Price can be reduce on application applied ETC : cheaper turbo, cheaper wastegate )
For Manual Transmission ( Softcore )
38mm Wastegate
Blow Off Valve
Extra Injector
Intercooler Kit
Expected horse Power 150WHP to 180WHP on Manual transmission
Boost at 0.6Bar
For Manual Transmission ( HardCore Modification Full internal Modification)
Original Turbosmart Ultragate 38mm Wastegate
Garrett T25 AR60 Turbo ( refurbish from Tong Turbo )
Blow Off Valve
Greddy E manage Ultimate
Denso 500CC injector x 4pcs
Custom Fuel Rail with fuel return and Fuel Regulator
Walbro 255LPH Fuel Pump
Metal Gasket
Intercooler Kit with 2.5inch Exhaust Piping + Japanese turbo muffler
Exedy Racing Clutch (3 Puck )
CP 75.5mm Low Compression Piston / ROSS 75.5MM Low Compression Piston
GP H Beam Con rod / Carrillo Con rod
Custom Made Aluminium Block Guard
Engine Oil Cooler Kit
Expected Horsepower 250WHP to 350WHP
Boost up to 1.6 Bar
With Installation and Dyno Tune
If with Manual Gearbox Conversion Set together with BOT add RM 4 000
RM 28 000
Toyota VIOS Turbo Auto Transmission Done by AZ Autoworks
ALL ITEM STATED ABOVE ARE BRAND NEW EXCEPT TURBINE REFURBISHED FROM TONG TURBO
Interested pls call Simon 016 6029888
NEW ARRIVAL
C&C Cutting
Fully aluminium
RM1588
Toyota VIOS 07
RM 280
High Impedance
Top Feed
RM988
actual photos
High Impedance
Top Feed
RM1188
actual photos
Brand: Synergy
Full Aluminium
RM 550
actual photos
Item comes with
Clutch Pump
Type : 4 x 1
RM 370
actual pics
For High Rev
Type : 4 x 1
RM 550
actual Pics
Type : 4 x 1
RM 499
actual pics
Turbo Manifold
RM 1500
Actual photos
Comes with
Open Pod Filter
Adapter
RM 170
Hi - Lo adjustment
Hi - Lo adjustment
1 Year Warranty
Ultra Racing
For Toyota Vios 07
Fender bar - RM270
RR bar - RM150
Room bar - RM 190
For Toyota Vios 03
High Performance
Bot On Turbo Kit
Item include
38mm Wastegate
Blow Off Valve
Extra Injector
Intercooler Kit
Boost at 0.6Bar
38mm Wastegate
Blow Off Valve
Extra Injector
Intercooler Kit
Boost at 0.6Bar
Blow Off Valve
Metal Gasket
Boost up to 1.6 Bar
RM 28 000
