RSS Sport Brake Disc Rotor For Perodua Proton Honda Toyota Mitsubishi
kenklyap
429
Brand New. Guarantee Original
RSS Sport Performance Brake disc kits
Featured & Benefits:
-Smooth casting that are finished to higher standards and high precision machining specifications to Fits the original equipment with mill balancing and double disc ground finishing. double disc grinding ensures parallelism, eliminates run out and provides near perfect disc thickness variation (DTV).
(New RSS rotors DO NOT need machining, ready to be installed right out of the box)
-Chamfer cross-drilled and rounded slotted braking surface design improve initial bite and continuous refreshing of the brake pad surface to control glazing, and debris (glazed pad emits a reflective surface and can cause a reduction in the braking performance due to excessive temperatures or excessive harsh braking)
- Wear indicator shows when the rotor needs replacement
- Maintains consistent stopping power with full control and confident braking with short stopping distances
-Improve cooling ,dissipation of heat and gases to reduce brake fade
(During long mountain descents, stop-start traffic and panic-stop braking temperatures can reach 650oc and above)
- Improved Wet Weather Braking performance
-Solve problem like Brake pedal pulsation (not to be confused with normal ABS operation), squealing, judder, warp disc (DVT), grinding noise, low brake pedal height, vehicle pulls to the left or right when brakes are applied and pedal feel
RSS Sport Brake Tech Tips:
Lubricate Brake Caliper guide, shims and rubber components.
Use silicone based lubricant or equivalent before installation
DO NOT use a petroleum based or spray adhesive product.
Lubricate all hardware rubber components and all metal to metal
contact points.
Give Brake Caliper guide and disc pad shims/insulators a thin film of lubricant. This will allow the shim to withstand normal brake pad movement without damage to the shim. Additionally, this helps dampen vibration.
Make sure the disc pads are tight in the caliper and torque the caliper to the housing.
Check the adjustment of the rear brakes. Adjust if necessary.
After cleaning all wheel hub
mating surfaces, install the wheels. Make sure they are torqued to manufacturer's specifications.
Model and Application:
Ford Fiesta
Honda Accord 03"-07"
Honda Accord 08"ON-
Honda Accord SiR CL7
Honda City Gm2 08-13"
Honda City GM6 2013-up"
Honda Civic EG/EK
Honda Civic EK9R
Honda Civic ES 1.7
Honda Civic FD 1.8/2.0
Honda Civic FB
Honda CR-V
Honda CRX
Honda FREED
Honda Integra DC2R
Honda Insight
Honda Jazz Hybrid GP
Honda Jazz Fit GK i-VTEC
Honda Odyssey RA
Honda Odyssey RB
Honda Odyssey RC
Honda Elysion RR
Honda Prelude BB1-4/BA8/9
Honda Prelude BB5-9
Honda Stepwagon
Honda Stream RN 1.7,2.0
Honda Stream RSZ 1.8
Mazda 2
Mitsubishi ASx
Mitsubishi AIRTREK
Mitsubishi COLT
Mitsubishi EVO 1-3
Mitsubishi EVO 1-3 REAR
Mitsubishi EVO 4
Mitsubishi FTO 1.8
Mitsubishi FTO 2.0
Mitsubishi GALANT
Mitsubishi GRANDIS
Mitsubishi LANCER GSR 1.8
Mitsubishi LANCER GSR 1.8 REAR
Mitsubishi LANCER GT 2.0
Mitsubishi LANCER GTE
Mitsubishi LANCER SPORTBACK
Mitsubishi RVR
Mitsubishi OUTLANDER
Nissan ALMERA
Nissan SYLPHY 2.0 G11
Perodua ALZA
Perodua ALZA FACELIFT 2014-UP
Perodua AXIA
Perodua BEZZA
Perodua KANCIL
Perodua KELISA
Perodua KENARI
Perodua MYVI 1.3 1ST GEN
Perodua MYVI 1.5 1.3 2ND GEN
Perodua VIVA
Proton EXORA
Proton GEN 2
Proton GEN 2 REAR
Proton INSPIRA 1.8/2.0
Proton PERDANA V6
Proton PERDANA V6 REAR
Proton PERDANA 2ND GEN
Proton PERSONA
Proton PERSONA RR
Proton PREVE
Proton PUTRA
Proton SAGA 2ND GEN
Proton SAGA 12V
Proton SATRIA GTi
Proton SATRIA NEO
Proton SATRIA NEO REAR
Proton SAVVY
Proton SUPRIMA S
Proton WAJA
Proton WAJA REAR
Proton WIRA 1.5
Proton WIRA 1.6/1.8
Proton WIRA 1.6/1.8 REAR
Toyota ALPHARD
Toyota ALTIS
Toyota CALDINA GT4 TURBO
Toyota CAMRY
Toyota ESTIMA
Toyota FORTUNER
Toyota HILUX 2.5 KUN25
Toyota IS250 /
Toyota MARK X 2.5
Toyota MR-S
Toyota PREVIA
Toyota VANGUARD
Toyota VELLFIRE
Toyota VIOS 08"NCP93
Toyota VIOS NCP150 2013:-Up
Toyota VIOS OLD(03-07")
Toyota YARIS
VW SCIROCCO 2.0
VW GOLF GTI MK5
VW GOLF GTI MK6
And other not list above also available
COD Area:
- My Store (Kg Dato Harun, Tmn Medan, PJS5 Petaling Jaya)
- Bandar Sunway (Petron Petrol Station)
- KFC Kuchai Lama
Delivery or postage can be arrange :
-make arrangements for location delivery or postage
*Please contact me if you need any further information*
012 827 6800 Ken (call/sms/whatsapp)
012 388 2681(whatsapp only)
email: [email protected]
*DEALER WANTED*
Shop Address:
(Waze - YKL TRADING PJS5)
No 17 Pusat Perdagangan Pjs(PJCC)
Jln PJS 5/30,PJS5
46000 Petaling Jaya
Selangor Malaysia
me51n
29
Bro... preve how much per pair?
contact points.
Ford Fiesta
Honda Accord 08"ON-
Honda Civic EG/EK
Honda Civic EK9R
Honda Civic ES 1.7
Honda Civic FB
Honda CR-V
Honda CRX
Honda FREED
Honda Integra DC2R
Honda Insight
Honda Odyssey RA
Honda Odyssey RB
Honda Odyssey RC
Honda Elysion RR
Honda Prelude BB5-9
Mazda 2
Mitsubishi ASX
Mitsubishi COLT
Mitsubishi EVO 1-3
Mitsubishi EVO 4
Mitsubishi FTO 1.8
Mitsubishi FTO 2.0
Mitsubishi GALANT
Mitsubishi GRANDIS 2.4
Mitsubishi RVR
Nissan ALMERA
Perodua ALZA
Perodua AXIA
Perodua BEZZA
Perodua KANCIL
Perodua KELISA
Perodua KENARI
Perodua VIVA
Proton EXORA
Proton GEN 2
Proton GEN 2 REAR
Proton PERDANA V6
Proton PERSONA
Proton PERSONA RR
Proton PREVE
Proton PUTRA
Proton SAGA 2ND GEN
Proton SAGA 12V
Proton SATRIA GTi
Proton SATRIA NEO
Proton SAVVY
Proton SUPRIMA S
Proton WAJA
Proton WAJA REAR
Proton WIRA 1.5
Proton WIRA 1.6/1.8
Toyota ALPHARD
Toyota ALTIS
Toyota CAMRY
Toyota ESTIMA
Toyota FORTUNER
Toyota IS250/MARK X 2.5
Toyota MR-S
Toyota PREVIA
Toyota VANGUARD
Toyota VELLFIRE
Toyota YARIS
VW SCIROCCO 2.0
VW GOLF GTI MK5
VW GOLF GTI MK6
Call or Whatsapp
012 827 6800 / 012 388 2681
Please sms or email [email protected] if no reply
COD Area: Bandar Sunway (Petron Petrol Station)
Payment Method:
-COD
-Online banking/maybank2u/PBe Online Banking
*Dealer Wanted *
How much is your product for the Myvi 1.3 1st gen?
my toyota corolla seg 1.6(m) has been stolen at nzx, ara damansara last few days. i parked my car in front of a shop lots, it was parked facing towards the shop, and the thief even know how to shift in the reverse gear(blacktop 6 speed). damn i was so sad now. if u guys happen to c any white seg like my car, pls do inform me, thanks. my hp number:012-340 1819
model:toyota corolla 1.6(M)
year:1999
colour: pearl white
engine: blacktop 6 speed
interior:original seats. momo steering, momo...
