MULTI-MITE DE Powder for Human, Pets and Plants
All Other Stuff
sentinal3_16
181
5,018
Klang
MULTI-MITE Diatomaceous Earth (DE) Powder for Human, Pets and Plants
MULTI-MITE - ‘Special Grade’ DE POWDER
Can be used for bedding to kill bed bugs, on rugs where pets sleep, mix with pet food to kill parasits and worms in their stomach, dusting on plants to kill pests and so many more advantages of using Multi-Mite. Its safe and natural and full of mineral which is good for pets and plants. DE is very very sharp. It works by dehydrating anything that it touches.
Diatomaceous earth - Wikipedia, the free encyclopedia
Diatomaceous Earth Health Benefits? Why & How It Works
Diatomaceous earth has many benefits
Please google and you will find 1001 benefits and its cheap to buy.
There are many different grades of Diatomaceous Earth, all of which have
varying degrees of success for its purpose. The MULTI MITE ‘Special Grade’
powder i supply is ThE bEST available for this specific use!
MULTI MITE is a completely natural product made from single cell algae called Diatoms, it has so many applications, too many to list here. I have tried many type of DE powders - none perform to the level of this product, with proper and regular use virtually all types mite and fleas will disappear for good.
It can be used for parasite control on virtually all animals, it is not poisonous and can even
be used as a slug repellant! And against pet fleas and lice, it is also effective on most
forms of animal Mange.
MULTI MITE is highly effective against:
Ants, Aphids, Bollworm, Red Mite, Ticks, Fleas, Cockroaches, Clothes Moth, Corn Worm, Earwig, House Fly, Fruit Fly, Lead Perforator, Greenfly, Leaf Hopper, Lygus Bug, Mite, Black Fly, Salt Marsh Caterpillar, Pink Boll Weevil, Red Spider Mite, Box Elder Bugs, Carpet Beetles, Centipedes, Millipedes, Silverfish, Slugs, Snails, Bed Bugs and virtually all other insects.
It can be expected that virtually all insects will die from contact with MULTI MITE within a few days.
MULTI MITE DE can also have a very good long term residual effect, i.e. when applied to cracks and crevices & bedding. This long term protection and control of insects is achieved by MULTI MITE controlling parasites by physical means not chemical, and therefore denying them the ability to build up a resistance to it in future generations.
How To Use In Poultry:
MULTI MITE DE can control red mite in poultry houses when thoroughly applied to walls, floors, ceilings, perches, nest boxes and cages at 10-15g per square metre. It can also be applied directly to birds.DE has been used for at least two decades as a natural wormer for livestock.
Feeding:
For effective use, MULTI MITE must be fed long enough to catch any newly hatching eggs or cycling of the worms through the lungs and back through the stomach.
A minimum of 60 days is recommended with approx 2% of the dry weight added to the
food ration.
MULTI MITE can also be applied to livestock’s coats as an insect repellent/contact insecticide. Both internal and external parasite control will result in improved health, appearance and behavior, as well as assimilation of feed, which means improved weight gain and lower feed costs.
MULTI MITE is also used as an animal feed additive for cows, calves, horses, sheep, goats, pigs, rabbits, chickens,turkeys, ducks, dogs, cats, pigeons and other pet or farm animals.
The following are recommended feeding and application rates. All rates are for a 60 day period:
Poultry: 5g per 100g of feed; 15g in each nest box; a good dusting on perch ends and around the coop.
Pigs: 2g per 100g of feed (or 4g per 100g of feed for 10 days as a purge); dust or spray animals and bedding.
Horses: 5 ounces in daily feed ration per horse; freely dust bedding.
Dogs: 1 tablespoon per 1 daily food ration for dogs over 25kg; 1 teaspoon for puppies and small dogs
(under 25kg); rub into coat and sprinkle on bedding.
Cats: 1 teaspoon per day in daily food ration; rub into coat and sprinkle bedding.
Beef Cattle: 2g per 100g of daily food ration (or 4g per 100g of daily food ration for 10 days as a purge).
Dairy Cattle: 4g per 100g of daily food ration.
Calves: 1 ounce in morning milk per calf.
You should make a weekly check of your animal through the first 45 days of the feeding period for evidence of a reduction in protein content, parasites and ova in the faeces.
If you began feeding MULTI MITE DE to your poultry or livestock and notice a gain in production, this would be that the MULTI MITE reduced the parasite population resulting in decreased stress on the animal.
MULTI MITE provides a broad spectrum of naturally occurring chelated minerals. These include potassium, iron, calcium, magnesium, phosphate, sodium, titanium and others. Numerous accounts of gain have been reported when adding MULTI MITE to a ration. With the lack of mineralization in modern grains, it isn’t hard to think of the mineral benefits from a finely ground natural mineral product. Feeding a 2% of grain ration can take care of both de-worming and mineralization.
Most livestock will acquire a ‘taste’ for the mineral if a small amount is mixed in with other feed. MULTI MITE is a natural (not calcined or flux calcined) compound with many elements which include: Silicon Dioxide (SiO2) - 83.7%; Aluminium Oxide (A12O3) - 5.6%; Iron Oxide (Fe2O3) - 2.3%, Calcium Oxide (CaO) - 0.4%; Magnesium Oxide (MgO) - 0.3%; Other Oxides - 1.9%.
Analysis of Other Elements:
Copper - 2ppm; Strontium - 100ppm; Titanium - 1800ppm; Manganese - 200ppm; Sodium - 2000ppm; Vanadium - 500ppm; Boron - 50ppm; Zirconium - 220ppm.
INSECT CONTROL
Fly control is a major problem with all livestock operations and living areas. To reduce this problem MULTI MITE can be placed in tightly woven Hessian bags (beg macam guni) and hung in doorways. Livestock will be attracted to it and work the bag until their heads are covered with the powder. This will then repel flies. Mixing MULTI MITE with things that flies are attracted to around the farm, such as manure, may also cause them to ingest MULTI MITE in their attempts to eat the attractant.
Absorption and deodorization are natural features of MULTI MITE. These functions will continue to happen as undigested Powder passes through with manure. Reduced fly hatching is usually observed in manure from livestock fed on MULTI MITE Powder. Some diary and pig farmers are also spreading it in bedding (for odors and moisture control) in addition to that coming through the manure.
DUSTING
For crops and pastures use 6 to 10kgs per hectare (6 to 10kgs in calm air). Dust after rain, overhead irrigation, or after a heavy dew to increase sticking of the powder. Dust the plant upward from the ground, covering all stems, top and underside of leaves. For enclosed areas, use 1/2 to 3/4 lb. per 1000 square feet. Hang dust bags in doorways of barns, milking areas, etc. Sprinkle in areas where ants and roaches are present or areas in which they run, such as skirting boards, under sinks etc.
TREES
Sprinkle liberally on the ground and around plants base and overthe leaves. Tree trunks can also be painted with a mixture of MULTI MITE, water, linseed soap or a wetting agent. This will inhibit the migration of various fruit flies (maggot stage), worms and beetles (grub stage) and slugs. MULTI MITE is not harmful to Earthworms since they are structurally different from insects.
YOU WILL NOT FIND A MORE EFFECTIVE GRADE!!
100% NATURAL & ECO FRIENDLY PRODUCT!!
250g = rm15+Rm6 poslaju
500g = rm30+rm8 poslaju
1kg = rm55+rm10 poslaju
hi guys....
just bought a set of sport pedals... set of 2 for auto tranny.
my problem is that the new brake pedal is bigger that the original.
the new pedal 4 have screw holes... i was suppose to drill some holes on
the ori pedal so that i can bolt em up.... but it can't be done coz of the
different sizes...
currently thinking of adding a new metal plate to the old pedal.
the new plate will be identical in size to the new pedals...
i'm thinking of welding this plate to the ori pedal...
