Car LED Headlight Headlamp H4 H7 H8 H11 9006 9005
Car Culture
yafhomarketing
177
518
www.facebook.com
### Newest & Latest Products ###
# [USA Bridgelux S2 COB LED Headlight Conversion Kits] #
[ 8000LM 72w / Set @ Pairs]
Plug Type (set@pair):
#H4,Hi-Lo Beam ( 72W@high beam, 72W@ low beam)
#9006(HB4),single Beam (72W/lot,36W/bulb)
#9005(HB3),single Beam (72W/lot,36W/bulb)
#H11,single Beam (72W/lot,36W/bulb
#H8,single Beam (72W/lot,36W/bulb)
#H7,single Beam (72W/lot,36W/bulb)
Power: 72W/set(36W/bulb)
#LED Quantity(each bulb) : 2pcs @ 3pcs(H4)* Bridgelux S2 COB chips
Luminous Flux : 8000lm/set(4000lm/bulb)
Operating Voltage : DC 9-32V(fit 12V,24V vehicles)
Color Temperature : Pure White 6500K
Material : Aviation 6063 aluminum profile
Waterproof and Dust Seal Rate : IP68, IP67
Operating Temperature : -40-80 degree Celsius
Beam Angle: H4>270 degree@low beam,360 degree@high beam
: Single beam > 360 degree
Lifespan : Over 50,000hrs lifetime
Usage : headlight,fog light
#Bridgelux COB S2 LED headlight conversion kit
#Features:
---Super bright Bridgelux COB chip(USA),360 degree clear beam no blind zone
---Engineering beam pattern design throw light on road evenly at appropriate angle without foggy light
---Xenon white light reflect road paint/signs better to show clearer road situation
---All-in-one heat conduction+high speed mute fan system keep the light bulb in appropriate working temperature
---Built-in constant current CPU,instant full brightness without start-up relay
#Two-way heat dissipation chiannel
1) All-in-one aluminum profile as heat conduction system,360 degree heat radiating
2) High speed mute fan(12000R/Min),high Air flow for faster cooling rate
1) Easy install , 100% plug & play
2) Not effect car warranty
3) No need modified & cut wiring
4) 6 month products warranty
5) Products apply for all type car ( exclude decoding/canbus )
新款 Bridgelux S2 COB LED 大灯雾灯
LED Headlight /Foglight Bulb
---安装简单,无需接线 100% Plug n play
---冷光源,不热不烧 Low temp
---电路安全稳定 Circuit security and stability
---瞬间启动,亮灯不延时 No delay n warm up time
---高散热结构设计 High heat dissipation structure design
---节能省电 Energy Saving,Long life time
---批发价格 Wholesaler price
---邮寄全马各区 Postage Malaysia all area
---更多详情请联系我 Kindly contact for more detail
----+60162279186 Netz Chan
#YAFHOMARKETING ( FB Pages )
[youtube]5yweOAc1AAI[/youtube] led headlight 3.JPG
Stunning white Aston Martin DBS Completely detailed
Hello Forumers,
It's been a very long since our last post. It has been a very busy and we hadn't had the chance to blog and share with you all our work. Yeap, the title says it all. This DBS was thrashed in the docks for a month before it was released to our client. Allow us to share with you on what we did on this monster super car.
The surrounding of the logo is filled with dirt and stains...
