AUTORUN Energizer Engine Treatment
evo2006
187
4
A multi-function engine treatment, aimed to provide a protective coat for the engine. It minimises wear due to moving surfaces, reduces corrosion and gives excellent lubricity to the engine.Benefits
Unlike many lubricants, Autorun can be used with either regular or synthetic motor oil. Long term and regular use of Autorun will:
• Reduce overall engine wear and tear
• Minimise cold start damage
• Reduce engine noise
• Reduce maintenance and repair costs
• Protect turbo-charged engines
• Improve engine performance
• Improve fuel economy
• Increase power output
Benefits for your vehicle:
1.Engine run smoother and quieter
2.Increase power and prolongs life
3.Easier starts in any weather
4.Does not contain PTFE, maly or graphite
Why buy a car when Autorun makes your old car run like new again?
Just add AutoRun to your crankcase to quite engine noise and smooth out rough running. More than one million cars all over the world have had their performance restored by AutoRun.
You don't have to change your oil!
It is not necessary to change your oil before adding AutoRun to your car. Just put AutoRun in the crankcase and then follow the manufacturer's recommendation for oil change frequency.
Extra protection for newer engines too!
Protect your new car from the leading cause of engine repairs- friction. AutoRun dramatically reduces friction and heat and keeps engine parts performing as they should.
AutoRun is absolutely safe!
You can use AutoRun in any type of engine, gas or diesel, and it is compatible with all regular and synthetic oils.
Made in USA
Directions for use
1.Vehicle wear 80,000km or less
Add AutoRun
Once every 40,000km
2.Vehicle wear
80,000km to 120,000km
Add AutoRun
12 months or every 16,000km
3. Vehicle wear Over 120,000km
Add AutoRun
4 months/every 6,000km
Instructions:
1.It is not necessary to change your engine oil before adding AutoRun. Just pour AutoRun into the crankcase of your vehicle, then follow the manufacturer's recommedation for oil change frequence.
2. Cars and truks:
Add one bottle of AutoRun to the vehicle crankcase.
3. 4-cycle motorcycles:
Add 30ml of AutoRun for every litre of lubricant. Do not exceed recommended usage level.
RM110 per bottle
Autorun can cod or poslaju with additional postage fee
018- 3629928
<iframe width="335" height="250" src="http://www.youtube.com/embed/X0ma4jFL7GU" frameborder="0" allowfullscreen></iframe>
We've seen the Audi A5 gaining the extra doors, now the Audi A1 Sportback, which will be rolling into showrooms in early 2012, will come in five doors. The Audi A1 is made for the young, urban public. The dimensions of the new model is longer and measures 3.95 meters (12.96 ft) in length. It is several millimeters taller. It offers more space in the rear seats. The Audi...
