[WTS] Motul, Mobil 1, Royal purple,Amsoil,Redline, German Castrol Engine oil.
gjrforce
1,245
Royal Purple Engine Oil: 5w20, 5w30, 10w40
RM39 per bottle(948ml)
Mobil 1 Engine Oil: 0w20, 0w30 & 0w40, 10w30HM
RM42 per bottle(948ml)
Mobil 1 EP Engine oil: 5w20EP , 5w30EP , 15W50EP
RM45 per bottle (945ml)
Mobil Synthetic ATF
RM48 per bottle (945ml)
Redline Engine Oil: 5w20, 5w30, 10w30, 5w40, 10w40 & 15w50
RM55 per bottle(948ml)
Redline Gear Oil: MTL, MT-90, D4, High Temp ATF, Lightweight Shockproof, 75w90 & 75w90NS
RM55 per bottle (948ml)
Redline SI-1 Fuel System Cleaner - Single 15oz (443.6ml)
RM45 per bottle
Redline Water Wetter - Single 12oz (354.9ml)
RM45 per bottle
Amsoil XL Engine oil: XLM 5w20, XLF 5w30 & XLO 10w40
RM38 per bottle (945ml)
Amsoil Engine oil: ASM 0w20, ASL 5w30, ATM 10w30, AMO 10W40 & AFL 5w40
RM44 per bottle (945ml)
Amsoil T2000 Engine oil: SSO 0w30 , TRO 20W50
RM52 per bottle (945ml)
Amsoil Synthetic Manual Transmission and Transaxle Gear Lube 75W-90 MTG
RM53.5 per bottle (945ml)
Amsoil Synthetic Universal Automatic Transmission Fluid (ATF)
RM53 per bottle (945ml)
Amsoil Engine Flush (AEF)- Single 16oz bottle (473ml)
RM38 per bottle (473ml)
Schaeffer Supreme #7000: 5w20, 5w30, 10w30 & 20w50
RM32.5 per bottle (948ml)
Schaeffer #9000: 5W30, 5w40
RM37.5 per bottle (948ml)
Schaeffer 204 SAT
RM41.5 per bottle (948ml)
Schaeffer MolyEP Oil Treatment - Single Pint (473ml)
RM39.5 per bottle (473ml)
Chevron Supreme (ISOSYN)
RM26 per bottle (948ml)
Denso Iridium Power Spark plug
RM145 to RM220 per set (4 plugs)
NGK Iridium Spark plug
RM135 to RM320 Per Set (4 plugs)
OWS Plasma Iridium spark plug
RM160 per set.
Bosch Fusion Iridium spark plug
RM140 per set.
UOA kit (with TAN)
RM100
UOA kit (without TAN)
RM80
Nippon, Chevrolet and Hyundai Oil Filter
RM17 to RM32
b]Item(s):[/b] Engine Oil, Manual Gear oil, ATF, Iridium Spark plug.
Package includes: Engine oil, Manual Gear oil, ATF, Iridium Spark plug.
Price: RM28-RM300
Dealing method: By Malaysia Pos Parcel Service, Pos Laju.
Location of seller: JB
Contact method/details: email, [email protected], Welcome To MyOilStore.com
HP: 012-7101392, 02-90678154
gjrforce
1,245
Motul V300:
Redline all product:
Royal purple:
Schaeffer #7000:
Mobil 1:
Motul V300
gjrforce
1,245
Mobil 1 0W20,0W30,0W40 only RM37 per Quart.
Royal purple only 34 per Quart
Redline Engine oil only RM55 per Quart
Redline Gearoil only RM55 per Quart
Redline SI-1 only RM45 per bottle.
Amsoil 100% fully synthetic engine oil only RM40 per Quart
gjrforce
1,245
gjrforce
1,245
gjrforce
1,245
gjrforce
1,245
gjrforce
1,245
gjrforce
1,245
gjrforce
1,245
gjrforce
1,245
gjrforce
1,245
gjrforce
1,245
gjrforce
1,245
gjrforce
1,245
Just change the original L9 Turbo fuel pump from one from 2JZ,seems that the 2J fuel pump too large dy,crank boost til 1.5 bar oso too rich and will keep pop out fire at the exhaust....
At 1st i tot to change back to stock L9 Fuel Pump and i worry that it will supply insufficient fuel,then i go to look after for a Wira 1.6 Fuel Pump and turn out the Wira Fuel Pump look exactly the same as my original L9 Turbo fuel pump....i wonder does the flow rate same?
I test the original L9 Turbo...
