Made in USA 3" K&N Cone Air filter
sexycar
4,728
15
5,138
©ït¥ ðf Thïêvê§
100% original made in USA K&N 3 inch cone filter. Shipped in from K&N USA because this model cant be found here. It has a 3 inch inlet mouth that can be mounted on air rams plug & play. Suitable for all cars with air ram, easy installation. Call 017-3948736 if wanna buy, location Cheras. Full specs below:
Part RC-4180 Product Specifications
Product Style: Round Tapered Universal Air Filter
Air Filter Shape: Round Tapered
Base Outside Diameter: 6 in (152 mm)
Top Outside Diameter: 4.5 in (114 mm)
Flanges: 1
Flange Inside Diameter: 3 in (76 mm)
Flange Length: 1.75 in (44 mm)
Flange Type: Centered
Height: 6 in (152 mm)
Filter Material: Cotton Gauze
Top Style: Metal
Top Material/Finish: Chrome
Filter Re-Oiling Amount: 1.27 oz (38 ml)
Inner Wire: No
Weight: 1.8 lb (0.8 kg)
Product Box Length: 6.38 in (162 mm)
Product Box Width: 6.38 in (162 mm)
Product Box Height: 11 in (279 mm)
HI there all
jz ask u technical questions about the wira se car..im using stock 4g15 manual engine bought my car 4 months old..still brand new....
i wanted to mod to 4G's T engine dun care VR4, GSR or EVO1,2,3.....my questions is if i jz transplant the engine+ecu+wiring(or even +GB) ...do i need to change the radiator+aircond radiator to its own original respective engine?...or can i jz used stock wira radiator&aircond radiator?....
what about the power stereng pump?...aircond...
