Different between VDO & MMC in wira
wsonny
467
14
5,018
Ampang
Bro,
what is the different in VDO & MMC in wira 4G series? and how can i spot what ECU i'm using now in my wira 1.3 injection
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
Bro,
vdo use siemens vdo ecu (which the name vdo came from)
-different throttle body special to vdo model only
-use map sensor
-use crank sensor
-distributorless type ignition
mmc use mmc ecu
-similar to other 4g series throttle body type
-use maf sensor
-no crank sensor
-use distributor type ignition (or cam sensor)
  • Like
Reactions: Ehab abdallah
wsonny
467
14
5,018
Ampang
which mean MMC more better then VDO, and much more space for upgrading as it similar wit 4G series...
RENESIS VIII
7,000 RPM
7,063
950
Ipoh
Just check these areas that is circled. MMC is different in these areas and also some other less noticeable areas.
Bro. RENESIS showing that you need to have your engine washed.......hhahahhahah
RENESIS VIII
7,000 RPM
7,063
950
Ipoh
In this picture, it looks ok but I think it still needs more cleaning especially near the block area. A lot of engine oil residue. Difficult to clean that.
sweelt
Nov 6, 2016
2,306
248
663
Penang
MMC got trade in value. kedai potong still want, i think.
my wira 2002 VDO engine, they not even want to smell it. :sleep:
Hi all,
i driving a mazda lantis 323F with B8 turbo. Currently i am facing a problem..my engine mounting, no matter ori or local one...after a while then it broken already. it seem like the stock mounting cant take the increase power from the turbo engine.
i currently custom made one hard mounting (no rubber at all), it seem help but then it sacrify all the daily drive comfortability. u can feel the whole car is shaking when u release the throttle or at high rpm.
so, any good idea for...
