- Mar 3, 2005
- 8,180
- 3,678
- 5,213
SF, I think the vibration could be the engine oil...not 100% sure just some theory I have la....just want to ask what grade of engine oil you using? and to what extend is the vibration of the engine..if can record a video of the engine vibration and upload to youtube and post it here remember to show the engine bay and your RPM.
My guess is that, your engine is still cold and you are using 15W-50 (normal engine oil used in Toyota SC if no special request to use 10 or 5. If you are on 15 the oil will be thick when it's cold so when you start the engine, the parts are still not well lubricated causing more friction then more vibration and noise. After the oil gets to working temperature. the internal parts are properly lubricated then the vibration will reduce so as the sound.
If you experienced no drop in performance of the car, hard jerking even at working temperature only at cold start...then there should be nothing of an issue.
