Store Cleaning Used audio stuffs Clearance Sale
1) Rockford Fosgate Punch 250.2 62.5W x 2 Car Amplifier
-stereo, bridged mono or Tri-Way output
-125 watts x 2 at 2 ohms
-250 watts x 1 in bridged mode
-MEHSA mounting technology increases the heat transfer from the -MOSFET output devices to the heat sink, for higher power output, lower -operating temperatures, and greater reliability
-MOSFET power supply and output devices
-50-210 Hz high-pass/low-pass crossovers, 12 dB/octave
-TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise between the head unit and the amp.
2) Bazooka EL804 EL Series 8" Bass Tube
- efficient ported enclosure designed for corner mounting in your trunk, hatch or behind the seat of your pickup truck
- spring-clip wire terminals
- 4 ohm impedance
- frequency response 39-1,500 Hz
- handles 150 watts RMS
- sensitivity 102 dB
3) Alpine MRP-F306
MAX POWER (EIAJ)
* 75W x 4 (4 Ohm Stereo)
* 180W x 2 (Bridged 4 Ohm)
FEATURES
* RMS Continuous Power (Watt) (at 14.4V, 20-20 kHz): 4 Ohm Stereo (0.08% THD) 30W x 4; 2 Ohm Stereo (0.3% THD) 40W x 4; Bridged 4 Ohm (0.3% THD) 80W x 2
* S/N Ratio 100dBA
* Frequency Response (+0, -1dB) 10-50kHz
* 4/3/2 Channel Operation
* MOSFET Power Supply
Package deal : RM 650.00
PM or whatsapp 0123181839
- 4 ohm impedance
3) Alpine MRP-F306
MAX POWER (EIAJ)
FEATURES
* S/N Ratio 100dBA
