Originally posted by ARe-BeaR@Jan 23 2005, 11:28
Actually what is the purpose of this thing...????
If install can get more power ma....???
How much if complete set + installation..??? :D
oil catch tank is to reduce heat and avoid polluted air into intake manifold. if you check your car engine head cover, you will be able to see a hose connecting the engine head cover to the intake manifold. this is to remove heat from engine head to intake to combustion to exhaust and to environment.
when you fit in oil catch tank, the connection is from head cover to oil catch tank to environment. SHORT CUT! besides, close the pipe to intake manifold to avoid dust to go in. here, the oily heat will be transfer to oil catch tank and here the oil will be store while the heat release to environment. for your intake manifold, it will enjoy cleaner air for breathing. less heat on engine, HP increase!
Call me when you confirm want. I will assign you to a workshop at sunway.
