your 2 subs are svc and wired in parallel gives u 2ohm, so u need to find an amp that gives enough power to both subs at 2ohmacidcoller said:General
Output 4 Ohms 150W x 1
Output 2 Ohms 300W x 1
Signal-to-Noise Ratio >100
Frequency Response (±3dB) 20Hz - 500Hz
Total Harmonic Distortion 0.1%
Input Sensitivity 250mV - 4V
or
RMS watt @ 4 Ohm = 1x400w
RMS watt @ 2 ohm = 1x700w
RMS watt @ 1 Ohm = 1x1200w
Frequency Response = 20Hz - 2500Hz
or any suggest for spec i must get???
the 1st amp gives u only 300W at 2ohm, which means each sub gets 150W only, not enuff one...
the 2nd amp better, gives u 700W at 2ohm which means each sub gets 350W, should be enough la since the subs are 250W rms.
