who expert in ice please help me....help help...
oldskolboyz
780
appleyard said:
oldskol
pls reread my post if you dont understand what i'm trying to say.
1) Yes DVC is Dual Voice Coil, my question is which part of the ifo that this subs is DVC i only saw its a SVC subs.
2) And how would you know that 360w@4ohm is max power.... where did you get that info... or are you assuming that????
3) Why would he wired it to 16 ohm care to explain???? Even you get a top end amp wont even have much power in 16 ohm. Ever heard of parallel wiring?????
I'm not sure this amp is class A or B or A/B but this amp is too hot to handle :)
appleyard, why so angree..
No 1: I'm refering to energie 11/04/2006 "dual vc GT" in series
No 1: 150w X 2 & 380 X 1, I know very well Atomic brand.. I'm the victim
No 3: did you read my post on 13/04/2006 or you want me write it again here... 2pc DVC 4ohm connect in series will 4Ohm.. not 16ohm as my earlier post... I'm so sorry about it due to miscalculate... I admit that...
Kippo
263
acid,
i'm a bit rustly here so u need to make sure what i give is correct :D
you can run both JBL subs with that Atomic amp but a few settings need to be made.
1. Make same signal going to both Left - Right RCA input of the amp. You can use Y-splitter for the Left RCA cable from HU & plug it into L-R amp RCA input. So now both L-R amp input signal is same. Bass is mono so dont worry about the stereo thing.
2. If i'm not mistaken, Left channel of amp is 180deg. out of phase relative to Right channel of amp. So you need to do reverse polarity with one of the sub.
*others correct me if this is true. It could be true for some amp only*
3. You get bass but dont expect it to be loud since i suspect the Atomic amp is power rating is overrated. Also do not push the amp into distortion.
acidcoller
939
i think Atomic brand is very good becoz its normarlly brand for home theater of coz there are speacialist in a sound system..
anyoneagree with me..
acidcoller
939
kyheng said:
From the amount you pay for the amp you can know is the amp good or not...
i dont think so la bro
sometimes the product very low price but the quality is very very good..
i think ll model brand made from USA is a better from other made
i think la...
not sure..
r u agree?
oldskolboyz
780
Not all made from USA is better... some from Europe... DLS, Sinfoni, Brax, Helix, Genesis, Audison, PHD, Revamp, Xetec, Audio System, Steg... some from Japan Alpine F#1 & old V12 seris, Luxman, Naka... from US like Zapco, Tru, SS Human Reign, Orion HCCA G4/5 & XTR, PG, Mcintosh, PPI
kyheng
1,202
seremban
For me, cheap things dosen't mean that is no good, only most of the people think like this. If the US brand is really made in US, then the quality will be better than other that made in China or... But now most of the US brands are made in China.
acidcoller
939
i agrree u bro
now in malaysia very hard to find any product pure USA made..
erm..
anyone who know the brand and made from..?
kindly list for me
oldskolboyz
780
As I know only top model production still in USA...... why don't you change from USA product to Europe product.... like Brax, Sinfoni, Genesis, Audison, Audio System, DLS, PHD, Steg, Xetec, Helix....... for me best amp from US right know only Tru Technology, Sound Stream Human Reign 2/4 & several top model Zapco...
acidcoller
939
ooicc...
but i think very hard to find the acc shop while they sale this product..
can u PM me wheres i want find..?
oldskolboyz
780
Yup... U can survey at this shop KF Audio Aman Suria, ACP PJ, SoundQuest Cheras, KK Lau around PJ, MegaSound PJ if I not mistaken laaa.... but some of those product beyond your budget... 2 or 3 amp can get 1 new MYvi or Wira SE....
acidcoller
939
hehehe
watever tq
mayb i can improve my knowledge
r60262
282
increase you amp watt to support you woofer... use 1000w 2 channel
acidcoller
939
bro..
what ur means..
ermmm...
for examples
can i use this amp
General
Output 4 Ohms 150W x 1
Output 2 Ohms 300W x 1
Signal-to-Noise Ratio >100
Frequency Response (±3dB) 20Hz - 500Hz
Total Harmonic Distortion 0.1%
Input Sensitivity 250mV - 4V
or
RMS watt @ 4 Ohm = 1x400w
RMS watt @ 2 ohm = 1x700w
RMS watt @ 1 Ohm = 1x1200w
Frequency Response = 20Hz - 2500Hz
or any suggest for spec i must get???
Ever experienced engine stall with air-conditioner on when you car slow down? What if its happen at the moment when you in a middle of U-turn? I bet your heart will pounding rapidly.
FICD is a little device that will help you with this problem. The concept is, this device will allow vaccum leak by allowing more air into intake manifold hence engine have enough air and wont stall. Its also stabilize idle and drive will feel a little bit lighter with a/c on. For the one who familiar with...
