Perhaps this will explains better:What adapter is needed?
thank you ;)Ok, noted. I will check with my friend's shop and see if he has......
thanks. i think it would be easier to find after market rims for long term. haha..Sorry, ask 3 shops already don't have. Seems the adapter is very expensive and don't have much of your type of rims to balance so they did not invest in it.....
You need to go back to Citroen service center
Yup, the second shop friend apps me back later, ask me to tell you change the rims.....hhahahhaathanks. i think it would be easier to find after market rims for long term. haha..
You should try this Tai Soon tyre shop in batu caves,Hi, any c3 owner here? Just wondering which tyre shop in PJ area has the adapter to do wheel balancing on the original c3 rims?
yeah exactly, and that simple wheel balancer just isn't enough and doesn't take into account brake discs, hub etc.Do on wheel no need take out even.....
I was doing on wheel before but now back to off wheel because every time I need to do some repairs requiring the removal of the wheels the balancing tents to run even though I fit back to the same lugs it came out from. That is the only cons I have about on wheel balancing but they are very precise and accurate, no vibration until top speed....yeah exactly, and that simple wheel balancer just isn't enough and doesn't take into account brake discs, hub etc.
I should do a quick review of the place and share it here
