Hi, this will be late reply, I just got signup..anyway S90 Royal is a very smooth and comfort car BUT just make sure the car is electronically sound, not false signal on the engine management system. Check the plug wiring connector as this tend to crack and deteriorate. You can send it to a local Volvo specialist shop to check it for you. If mileage has clock too high than forget it. Better be safe than sorry...
---------- Post added at 10:58 AM ---------- 6 hour anti-bump limit - Previous post was at 10:54 AM ----------
Hi, this will be late reply, I just got signup..anyway S90 Royal is a very smooth and comfort car BUT just make sure the car is electronically sound, not false signal on the engine management system. Check the plug wiring connector as this tend to crack and deteriorate. You can send it to a local Volvo specialist shop to check it for you. If mileage has clock too high than forget it. Better be safe than sorry...good luck
