MONOBLOCK HIGH PERFORMANCE BRAKE KIT
PCD 114.3 / Disc rotor 323mm, been used 12000km
An aluminum monoblock caliper takes this high-performance brake kit to an even higher level.
■High-durability, high-precision, lightweight brakes have been achieved through use of a monoblock aluminum 4-pod caliper.
■Most calipers are constructed in two pieces (separate type), but a monoblock caliper fuses these pieces into one. This reduces caliper deformation during sudden, hard braking, and improves braking performance.
■ Elimination of bolt-induced elongation provides for linear braking characteristics.
With other types of brakes, when pressure from the piston applies the pad to the disc, force is also applied to the caliper alignment eye, causing a loss in braking performance. However, with our brakes, because the monoblock caliper is a single piece, this loss does not occur, thus achieving more linear, direct braking.
Interested please call 0162211261
