I guess everyone here have or has been through a hard time when you accidentally going through Malaysian road that filled with potholes,uneven surfacing,or simply vandalized by making the surface sliperry by mean of excessive oil at strategic place.
So I salute this motorcycle club DRMOTO that making a huge,personal effort to warned other road user,not just a motorcyclist,& to those higher authority to see the road that need some serious attention.
One of the way that they would do with those serious potholes that have claiming a countless other innoncence victim',is to marked it with yellow spray.The bright paint with notes on the road would help other to avoid running through the potholes that would ruined your day.
If that was not enough,they will put a reflector so in dark area or area without proper lightning,road user should be able to see the potholes as well,& if the higher authority think that they are joking around.....the final step would be the flower plant.
Flower plant?Yeah you hear it right.The crew would just put the flower plant inside the potholes,& let it grow there until patching/repair crew arrived.
Some other extras' to marked the big holes' in the road that left unrepaired is even more funnier,but with good intention & for the other road user to easily spot the potholes that was way too dangerous.
The fallen heroes",in this case,your everyday bent,dented,damaged beyond repair wheels & sportrim would be used as well to marked those pothole.No kidding,& some of them come from the people that actually becoming a victim of those potholes themselves....usually a motorcyclist.
So let see some of their work' to remind all the road user to avoid the annoying potholes that we see everyday on our live.....
Recently make into the newspaper.....I support this cause !
& the potholes with the sportrim,& the flower plant......finally get the much needed repair & fix.But the MPSJ left the note that the crew made before....(MPSJ BAHAYA) as the reminder.
Uploaded with ImageShack.us
Salute to the DRMOTO & the founder,Lando Zawawi.All the pictures via his FB acc. (Lando Zawai Lvr)
Good job & thanks to such a good effort......you definitely deserve my respect !:wavey:
