Uninstall RSM cause vvtl-i disable .....
CelicaZZT231
42
1,508
hi.. just for sharing a friend of mine had get a rsm installed and he remove by just unplug the cable... finally it cause the vvtli not function after 6k rpm.. and the engine light on when driving ...after plug in the rsm everything go back to normal... so funny thing but as i know rsm only the information display gadget rite... conceptually wont effect the engine management.....
BA5
300
dunno bout it...but i heard that somehow rsm increases the factory rpm limiter...
benyeap
244
RSM acts as speed cut remover too
E-Tech
1,115
256
3,183
Johor
Bro
speed wire if cut then it must be joined back when remove da rsm.
Other should be just tap da signal only so no problem.E.g rpm, 12v and grd. N maybe
g sensor.
Tq
cuscostrutbrace
987
62
3,028
RSM only remove speed cut but not rev cut,if you remove the speed cut,RSM need to be used all the time,if you remove the RSM,the wiring should be changed back to original.Or else,that will happen.
Hi all,
Just want to ask if anybody got experience with double sided tape on car panels.
The reason is that I would like to stick some rubber or pads to my front passenger door. There has been an accident and even though fixed, wind and road noise can be heard. When I inspect, there is one part that doesn't seal well (got slight gap).
I have tried to stick before, but those stupid cheap tape deteriorated and not only the rubber fall off, but cleaning it up is a PITA. Full of sticky...
