Tyre Pressure for 195/45/R15
Wilson13B
296
30
528
How much pressure should i pump into this tyre ?
AT the moment i pump like 35psi for the front and 34psi for the rear ....
I see on my Polo with 215/40/R17 recommended pressure is 40Psi ... is it normal to run such high tyre pressure ?
Thanks for any replies .
How is the handling and ride with 35psi? If okay, just continue using.
40psi seems a bit on the high side, but the lower the aspect ratio (40 series) more air pressure is required to hold up the car.
LesleyAprotto
Banned
Jun 16, 2012
1,339
287
683
I think 40psi is too much, considering yours is a very low profiled tyre 45 series
At this pressure, if you run into potholes, chances are your suspension, rims and tyre may not be able to take it...
So, a slightly soft feel should absorb any hard bumps that you may encounter...
I think 33-34 psi should be more than sufficient...
Actually for ultra low profile like 40 series more air pressure is required. As for going into potholes, with more air pressure actually helps to save the rims. The tyres do not get compress to hit the rims....
D7zul
2,697
848
Shah Alam
all tyres have its own maximum pressure written on it..
as long as u don't exceed d limit i think its ok
for me, my 205/40/r16 i pump around 32 psi
I'll try to pump in 35psi later :biggrin:
euro2nride
162
10
5,018
kl
Where do u guys get such tire sizes? 195/45/15? 205/40/16?
Sorry for my noob question....
Bro. D7zul, The maximum pressure mentioned on the tyres is the maximum pressure allow to mount the tyres, means to pump up the tyre sidewall into the edge of the rims.
If unable to mount the tyres at the maximum pressure, then it has to be deflated and additional tyre mounting lube applied to ease the mounting....
It is not the maximum pressure for use.....by then will be very bumpy and hard already......
---------- Post added at 08:26 PM ---------- 6 hour anti-bump limit - Previous post was at 08:23 PM ----------
Actually have but maybe not here or very rare. However 195/45R16, not 15, I have seen before.....
D7zul
2,697
848
Shah Alam
wrong no kot.. i forgot already my tyre size
long time didn't change tyre on my weekend car :biggrin:
i'll check it again later :rolleyes:
---------- Post added at 04:02 PM ---------- 6 hour anti-bump limit - Previous post was at 01:04 PM ----------
oh.. mine actually 205/45/zr16 :biggrin:
That one quite common.....:rofl:
Hi guys, my Honda Civic Ek Type R has been stolen 1week ago, i've made police report but nothing goes on, my fren has spotted the car in few diffrent places but lost track, suspected 2 malay guys ware driving dangerously and freaking fast on the road using the same reg no plate and the car still in 1piece...pls pls pls help me contact me 012-2629705, or 03-21159999 rakan cop, rewards will be paid off, tq so much ur all
HUKM tun razak heading sungei besi
MRR2 heading ampang
sungei besi...
