Trackday attendance 2nd april
kelisa6009
Over 10,000 RPM!
17,144
40
Penang Kia
faisal said:
Kelisa on AD07 165 55 14 with std suspension can take Turns 5&6 flat.. awesome-ness
You might osa wanna upgrade your brake pads.
in the Kompak Car Battle I could outbrake everyone, which was stoopid really since the Kelisa hasn't much top speed you can really wait till the last possible moment before braking
i have already upgrade my brake to MYVi...so that that my braking is superb..the only thing is that my tyre....giving me problem in each corner...like drifting....spin few time especially the 90 degree turn....nearly kena hit by other car....
faisal
1,864
54
The Valley
ignition.my
AD07 tyre wear rate is high but it also depends on tyre presure and driving style too.
Sepang Circuit surface is not abbrasive. It doesn't wear tyres like Batu 3 or Pasir Gudang Circuit does.
What do you mean by Myvi brakes? The entire system or just calipers?
Be careful if you just change front calipers and disc. The Brake balance will be off. The Kelisa comes with drum rears.
jinkl
4,624
376
3,183
there are semi slicks available for 14" which is for sure suitable for the kelisa
grip should be superb. hehe i first used semi slicks , wasnt fully satisfied, changed to full slicks and i started to smile all the way. btw full slicks 2nd hand are way cheaper :P
kelisa6009
Over 10,000 RPM!
17,144
40
Penang Kia
i change the whole set of myvi brake to my kelisa.....nicely fit to my car and the responce is better
kelisa6009
Over 10,000 RPM!
17,144
40
Penang Kia
klgauto said:
could be your tire or enter speed too fast
i guess because of my tyre....not much grip during corner....that y i spin few times and hard to control my car during corner
klgauto
Over 10,000 RPM!
12,199
10
Klang Sentral
www.klgauto.zoomshare.com
than after few times i spin i slow down to 80km and down shift to 2nd gear at conner15 .....than after apex i full throttle to 8k RPM than up shift to 3rd gear ..8k than up shift to 4th gear to 8.5k rpm 190km before conner 1 200m brake hard...eee...150m down shift 3rd gear......eee...50m down shift 2nd gear 80km into apex half throttle than full throttle into conner 2 .........some time drift at conner 2 .....kakaka
kelisa6009
Over 10,000 RPM!
17,144
40
Penang Kia
klgauto said:
i also spin few time at conner 15/14 because of my enter speed too fast ....
i always spin on the corner number 9....i spin there twice..usually which is the corret gear and speed u need to enter that corner?
kelisa6009
Over 10,000 RPM!
17,144
40
Penang Kia
what is the max top speed u hit on the track...mine highest is 140 only
jinkl
4,624
376
3,183
klgauto : wht car did u use on the track , wuish 8krpm :) .vtec ?
klgauto
Over 10,000 RPM!
12,199
10
Klang Sentral
kelisa6009.....for my car at conner 9 use 2nd gear , if 3rd gear the exit speed not fast enough.......you need to try as many time you can and find out what the best gear for your car at that conner
my highest speed 190km before conner1 / 200m
jinkl.........TE71 with 4age20v BT
kelisa6009
Over 10,000 RPM!
17,144
40
Penang Kia
ohhh...i use 2nd gear also...but like to much power....the wheel spin on the track..that y my car out of control on that coner...use 3rd gear..not enough power...wooo....190...very very fast...
klgauto
Over 10,000 RPM!
12,199
10
Klang Sentral
i think better change good tire next time ............sound like not enough grip......190 people also potong me at track lor .........some of the turbo car i think there can hit 2++
kelisa6009
Over 10,000 RPM!
17,144
40
Penang Kia
yaya...next time i plan o use better tyre..hehe...190 ppl smoke u also....all very keng car leh...i guess that that i am the slowest car in the track
Can somebody tell me or show me how to mod Gen2? I only want the mod of body part not engine.. can Gen2 look more "GANAZ" want on the road... Show me laa abang-abang.. kakak-kakak..10q haa..... :biggrin:
