i wish to let go my KE70 equipped with;
- Levin 4AGE 16v TVIS 140hp engine (endorsed)
- head port & polish
- grind valve
- full high-speed balancing crank shaft
- AE92 High comp piston & piston ring changed
- SARD fuel regulator
- TODA adjustable cam pulley
- TRD flywheel
- TRD clutch set
- APEXI 4-1 extractor and exhaust
- POTENZA GYMKHANA soft-hard absorber
- RSR spring
- caster kit
- AE86 gearbox
- AE86 long shaft
- AE86 4.3 axle with disc brake
for further info kinda call
0164111765 dave
- grind valve
- TRD flywheel
- TRD clutch set
- RSR spring
- caster kit
- AE86 gearbox
- AE86 long shaft
0164111765 dave
