SP MAT SoundProofing
SOLID QUIETNESS MAKES DRIVING A PLEASURE
Feeling irritated while driving due to the excessive noise from the road? Unsatisfied with the bass produce by your speaker? Feeling unsecured with noise coming in from the thin metal body of your car?
All of this could come to an end with this SP MAT SoundProofing.
This soundproofing material is made from modified bitumen where by it contains butyl core complete with alluminium backing. Modified bitumen is different from others where by it can with stand higher temperature than nomal bitumen.Normal bitumen will get harden easily.Once it is harden no damping effect will occur thus no sound proofing effect.This is a modified bitumen to stand this kind of extreme wheather.
Benefits of Sound proofing
• Reduce excessive noise created by the road from the car tyres.
• Reduce significantly on exhaust sound when stick on the correct area.
• Increase solidness of the car body such as doors, bonnet and other parts of the car.
• Increase the production of bass from your car speaker.
• Reduce vibration of door panels if correct installation had been done to the doors.
Installation guide:
• Clean the surface of the area that is intended to be sound proof.
• Measure the length of area that is intended to stick and cut it.
• Remove the paper and stick it accordingly to your preference (just like double sided tape)
• Use a cloth or a flat roller to press the mat on to the surface that has been stick.
• Pack your stuff and feel the differences
• Installation service is provided upon request (extra charges)
Important:
• Ensure that the surface of installation to be done are free from oil, grease, dirt & others in order to obtain good adhesiveness.
Dimension per piece:
• Length : 760mm
• Width 300mm
• Thickness : +/- 3mm
Price:
• 4pcs/box RM138
• 6pcs/box RM198
Best effect if installed with Superlon 6mm with self adhesive.
Superlon is also available at RM35/pc for the size of 3ft x 4ft x 6mm.
Promotion period (22/11/07-31/12/07): First box of SOUNDPROOFING MAT at Rm138/Rm198, second box of SOUNDPROOFING MAT gets a 10% DISCOUNT from the original price, while the third box of SOUNDPROOFING MAT gets a FREE Superlon worth Rm35/pc.
Location to C.O.D:
• Wangsa Maju
• Cheras
• Kuchai Lama
• Old Klang Road
• Mid Valley
For further information:
• Call Lim : 016-2816233
Installation guide:
Important:
• Length : 760mm
• Width 300mm
Price:
• 4pcs/box RM138
• 6pcs/box RM198
Location to C.O.D:
• Wangsa Maju
• Cheras
• Kuchai Lama
• Old Klang Road
• Mid Valley
