Skyline Build Numbers
farizio
482
37
Just posting this here for my own reference, and for your reading pleasure.
Skyline History and spec details
BNR32
Production Figures 43,934 vehicles.
Descriptions Standard 40,390
NISMO 560
V-spec 1,453
V-specII 1,303
N1 version 228
Chassis Numbers GT-R NISMO (sold 500) : BNR32-100000 - BNR32-100560
Version 1: 21/08/1999- : BNR32-000051 - BNR32-017466
Version 2: 20/08/1991- : BNR32-212001 -
Version 3: 01/01/1993- : BNR32-300001 - BNR32-314649
Annual Production 1989: 4,555
1990: 8,426
1991: 7,081
1992: 7,961
1993: 6,204
1994: 7,465
Body Colours Version 1
- Gun Grey Metallic (KH2)
- Jet Silver Metallic (KG1)
- Dirk Blue Pearl (TH1)
- Red Pearl Metallic (AH3)
- Black Pearl Metallic (732)
Version 2 / Version 3
- Cristal White (326)
- Spark Silver Metallic (KL0)
Version 1 Released: 21th August 1989
Produced to make victory at Group A race.
Length: 4,545mm x Width: 1,755mm x Height: 1,340mm
Wheelbase: 2,615mm
Curb Weight: 1,430kg
Max Power: 280ps/6,800rpm
Max Torque: 36.0kg-m/4,400rpm
Engine: RB26DETT
Displacement: 2,568cc
* Twin ceramic blade turbochargers.
* Electrically controled torque split four wheel drive (ATTESA E-TS).
* 4 wheels multi-link suspensions.
* 225/50-16 tyres.
NISMO Released: 11th March 1990
Produced 560 BNR32 GTR Nismo as Group A evolution model.
* Metal blade turbochargers.
* Additional air intake on the front bumper.
* Bonnet hood top spoiler
* Bigger side sill protector.
* Rear auxiliary small rear spoiler.
* Less rear wiper.
* Less ABS.
* Less air-con.
* Less intercooler net.
* Curb Weight: 1,400kg (weight reduction by 30kgs.)
Version 2 Released: 20th August 1991
* Side impact door beam.
* Factory optional driver side airbag.
* Seatbelt warning indicator.
* Shock absorb steering wheel pad.
* Fireproofed interior materials.
* Revised headlight lense and H1 type headlight bulb.
* Curb weight: 1,480kg (50kgs increased.)
Version 3 Released: 3rd February
* Pull type clutch.
* Revised rear diff cover. (1994 onwards.)
V-spec Released: 3rd February 1993
Anniversary model for 3 years champion of Group A race.
* Height: 1,355mm (+15mm)
* Brembo brake calipers and discs.
* BBS aluminium wheels.
* 225/50-17 tyres.
* Curb weight: 1,500kg (20kgs increased.)
V-spec II Released: 14th February 1994
*Anniversary model for 4 years champion of Group A race.
*245/45-17 tyres.
*V-specII Sticker.
N1 version Base car for N1 Taikyu Championship Series. (Group N endurance race equivalent.)
* Less rear wiper.
* Less ABS.
* Less air-con.
* Brake cooling air guide.
* Non projector headlights.
* Metal blade turbochargers. (V-spec N1 and V-spec II N1.)
BCNR33
Production Figures 16,520 vehicles.
Descriptions Standard 9,871
V-spec 6,551 (Incld. N1 version)
- Super Clear Red (AN0)
- Deep Marine Blue (BN6)
- Black (KH3)
- Dirk Grey Pearl (KN6)
- Midnight Purple (LP2)
- White (QM1)
LM Limited
- Champion Blue (BT2)
- White (QM1)
- Sonic Silver (KP4)
- Dirk Grey Pearl(KN6)
- Black(KH3)
- Super Clear Red II (AR1)
Version 1 Released: 16th January 1995.
Length: 4,675mm x Width: 1,780mm x Height: 1,360mm
Wheelbase: 2,720mm
Curb Weight 1,530kg(GTR STD) / 1,540kg(GTR V-spec)
Max Torque: 37.5kg-m/4,400rpm
* Compared with BNR32, Length +130mm, Width +25mm, Height +5mm (compared with BNR32 V-spec), Wheelbase: +105mm.
* Increased torque by 5kg-m.
* 245/45-17 tyres.
* Increased standard boost pressure by 0.09bar (BNR32:0.75bar / BCNR33:0.84bar)
* Brembo brake calipers and discs as standard.
* Brake cooling air guide for V-spec.
* Active LSD and ATTESA E-TS PRO for V-spec.
* Harder suspensions for V-specs.
* Strut tower brace, extra reinforcement body panels.
* Drivers SRS Airbag.
Version 2 Released: 22nd January 1996.
* Revised body colour in red and silver.
* Revised steering wheel design.
* Passengers airbag.
* Reviced shape and material on dashboard and centre cruster.
LM Limited Released: 21st May 1996.
Taken limited order by end of July.
Anniverysary model for participation of Le Mans 24 Hours Race.
* Exclusive colour: Champion Blue (BT2)
* Front bumper with extra air duct.
* Bonnet hood top spoiler.
* Carbon fibre rear main spoiler.
* Exclusive decal on c-piller.
Version 3 Released: 3rd February 1997
* Xenon headlights.
* Rear fog lights.
* Bigger front splitter with bigger brake cooling air duct (20mm lower).
* Revised ABS control programme.
* Reinforced brake pedal bracket.
* Reinforced rear suspensions member fitting.
* Rear floor reinforcement bar.
* Revised colour scheme interior. (Version 1/2: Grey with blue, Version 3: Grey with red.)
N1 Version Released: 3rd February 1997.
Based on V-spec.
* Thicker piston second land. (Std: 4.0mm N1: 4.6mm‚Ö)
* Reinforced material used for conn-rod bearings.
* Reinforced air inlet hose.
* Front mounted engine oil cooler.
* N1 water pump. (bigger inperer to prevent bubbling.)
* Reinforcement around cylinder block head bolt boss.
* Narrowed distance between two piston rings. (Std: 1.5mm / N1: 1.2mm)
* Revised camshaft profile. (exhaust overlap: STD 0 degree / N1 5 degrees).
* Extra air intake on front bumper.
* Intercooler air guide.
* Carbon fibre front under cover.
* Less rear wiper.
* Less air-con.
BNR34
Production figures 7,849 (by end of February 2000)
Descriptions Standard: 3,169
V-spec: 4,619
V-spec N1: 31
- Bayside Blue (TV2)
- White (QM1)
- Athlete Silver (KV2)
- Black Pearl Metallic (GV1)
- Active Red (AR2)
- Lightning Yellow (EV1)
- Midnight Purple II (LV4) / Limited edition of 300.
- Midnight Purple III (LX0) / Limited edition.
Version 2
- Sparkling Silver (WV2)
- White (QM1)
- White Pearl (QX1)
Version 1 Released: 8th January 1999.
Length: 4,600mm x Width: 1,785mm x Height: 1,360mm
Wheelbase: 2,665mm
Curb Weight: STD 1,540kgs / V-spec 1,560kgs
Max torque: 40.0kg-m/4,400rpm
* Length: -75mm, Width: +5mm, Wheel base: -55mm (compared with BCNR33).
* Increased torque by 2.5kg-m from BCNR33.
* 245/45-18 tyres.
* Twin ball bearing ceramic turbochargers.
* Boost pressure increased to 0.93bar from 0.84 of BCNR33.
* Getrag 6-speed manual gearbox.
* N1 conn-rod bearings as standard.
* Red engine cover.
* Plastic cambelt cover. (BNR32/BCNR33: metal)
* Lightweight turbo outlet tube. (-1.8kg)
* Multi Function Display.
* Engine immobilizer.
* Herical LSD on GTR Std.
* Brake cooling air guide on V-spec.
* Front diffuser and rear carbon fibre diffuser on V-spec.
* Active LSD and ATTESA E-TS PRO on V-spec.
* Harder suspensions on V-spec.
* V-spec special tacho meter.
Version 2 Released: 28th August 2000.
* N1 rear brake calipers on all GTR range.
* Aluminium pedals.
* Revised interior colour scheme. (Version 1: Grey cloth / Version 2: Black cloth)
* Revised centre cruster colour scheme (Version 1: Gold / Version 2: Illidium)
* Clear front indicators and side repeaters.
* Additional body colour: White Pearl and Sparkling Silver.
* Carbon fibre bonnet with NACA duct on V-specII (-4kgs).
M-spec Released: 8th May 2001
* Based on V-specII.
* Full leather interior.
* Front seat heater.
* Special ripple control shock absorber.
* Special rear stabilizer.
* Fine grip type steering wheel with gold stitching.
* Aluminium Bonnet. (Optional: Carbon Fibre Bonnet with NACA duct.)
* Exclusive body colour.
* Limited edition of 50 per month.
N1 Version * N1 Ball bearing metal turbochargers.
* N1 Bigger rear brake caliper and discs.
* Big capacity front mounted engine oil cooler.
* Less electric control of wing mirrors. (non colour coded.)
* Plastic hand brake lever. (Std: leather)
* Plastic centre console lid. (Std: leather)
* Less air-con.
* Less rear wiper.
* Less rear fog light.
* Less remote control key.
* Less audio.
V-specII NUR
M-spec NUR Released: 26th February 2002.
* Limited edition of 1,000 as BNR34 GTR Final Edition.
* N1 turbochargers.
* N1 Engine block.
* N1 Pistons with weight balancing.
* N1 Piston rings.
* Weight balanced conn-rods.
* N1 Oil pump.
* N1 Water pump.
* N1 Exhaust manifold.
* N1 Intercooler air hose.
* Exclusive cylinder head cover colour.
* Exclusive gold VIN plate.
* Exclusive rear emblem.
SPEC LISTS -
BNR32
- GTR Std, August 1989 - July 1993
- GTR Std, August 1993 -
- V-specII, February 1994 -
BCNR33
- GTR Std, February 1997 -
- V-spec February 1997 -
BNR34
- GTR Std, October 2000 - August 2002
- V-specII October 2000 - August 2002
(Incld. V-spec, January 1999 - September 2000 / V-specII Nur, February 2002 - August 2002)
- V-specII N1 October 2000 - August 2002
- M-spec, May 2001- August 2002
(Incld. M-spec Nur, February 2002 - August 2002)
BNR32 August 1989 Onwards
Basic Information
Power Delivery System 4WD
Model Code KBNR32RXFS
Gearbox 5-speed Manual Gearbox
Measurement
Length x Width x Height 4545 x 1755 x 1340mm
Cabin Length x Width x Height 1805 x 1400 x 1090 mm
Wheelbase 2615mm
Tread (Front) 1480mm
Tread (Rear) 1480mm
Ground Clearance 135mm
Curb Weight 1430kg
Passengers 4 persons
Doors 2 Doors
Engine
Type Water Cooled In-Line 6 DOHC 24 Valves Intercooled Twin Turbocharged
Remarks -
LEV -
Engine Model RB26DETT
Turbocharger Turbochargers with Intercooler
Displacement 2568cc
Compression Ratio 8.5
Bore 86.0mm
Stroke 73.7mm
Fuel Injection System Nissan EGI(ECCS) Electric Fuel Injection System
Fuel Type Unleaded Premium Petrol
Fuel Tank Capacity 72L
Performance
Max Power 280ps/6800rpm
Max Torque 36.0kg-m/4400rpm
Fuel Consumption (Japanese 10/15 Mode) 7.0km/L
Minimum Turning Radius 5.3m
Powertrain / Steering System
Steering System Rack and Pinion with Power Assist
Tyres (Front) 225/50R16 92V
Tyres (Rear) 225/50R16 92V
Brake System (Front) Ventilated Disc
Brake System (Rear) Ventilated Disc
Suspensions (Front) Independent Strut Multi Link
Suspensions (Rear) Independent Strut Multi Link
BNR32 August 1993 Onwards.
Basic Information
Model Code KBNR32RXFS7
Measurement
Wheelbase 2615mm
Tread (Rear) 1480mm
Curb Weight 1480kg
Doors 2 Doors
Engine
Remarks -
LEV -
Displacement 2568cc
Bore 86.0mm
Stroke 73.7mm
Performance
Fuel Consumption (Japanese 10/15 Mode) 8.2km/L
BNR32 V-specII February 1994 Onwards.
Basic Information
Model Code Nissan E-BNR32
Measurement
Length x Width x Height 4545 x 1755 x 1355mm
Wheelbase 2615mm
Tread (Rear) 1480mm
Ground Clearance 140mm
Curb Weight 1500kg
Doors 2 Doors
Engine
Remarks N/A
LEV N/A
Displacement 2568cc
Bore 86.0mm
Stroke 73.7mm
Performance
Minimum Turning Radius 5.5m
Tyres (Front) 245/45ZR17
Tyres (Rear) 245/45ZR17
BCNR33 February 1997 Onwards.
Basic Information
Model Code Nissan E-BCNR33
Measurement
Length x Width x Height 4675 x 1780 x 1360mm
Cabin Length x Width x Height 1820 x 1415 x 1090 mm
Wheelbase 2720mm
Tread (Rear) 1490mm
Ground Clearance 145mm
Curb Weight 1530kg
Doors 2 Doors
Engine
Remarks N/A
LEV N/A
Displacement 2568cc
Bore 86.0mm
Stroke 73.7mm
Fuel Tank Capacity 65L
Performance
Max Torque 37.5kg-m/4400rpm
Fuel Consumption (Japanese 10/15 Mode) 8.1km/L
Minimum Turning Radius 5.7m
Tyres (Front) 245/40ZR17
Tyres (Rear) 245/40ZR17
BCNR33 V-spec February 1997 Onwards.
Basic Information
Measurement
Wheelbase 2720mm
Tread (Rear) 1490mm
Curb Weight 1540kg
Doors 2 Doors
Engine
Remarks N/A
LEV N/A
Displacement 2568cc
Bore 86.0mm
Stroke 73.7mm
Performance
BNR34 October 2000 Onwards.
Basic Information
Model Code Nissan GF-BNR34
Gearbox GETRAG 6-speed Manual Gearbox
Measurement
Length x Width x Height 4600 x 1785 x 1360mm
Cabin Length x Width x Height 1780 x 1400 x 1105 mm
Wheelbase 2665mm
Tread (Rear) 1490mm
Curb Weight 1540kg
Doors 2 Doors
Engine
Remarks -
LEV -
Displacement 2568cc
Bore 86.0mm
Stroke 73.7mm
Performance
Max Torque 40.0kg-m/4400rpm
Minimum Turning Radius 5.6m
Tyres (Front) 245/40ZR18
Tyres (Rear) 245/40ZR18
BNR34 V-spec January 1999 Onwards.
BNR34 V-specII October 2000 Onwards.
BNR34 V-specII NUR February 2002 Onwards.
Basic Information
Measurement
Wheelbase 2665mm
Tread (Rear) 1490mm
Ground Clearance 130mm
Curb Weight 1560kg
Doors 2 Doors
Engine
Remarks -
LEV -
Displacement 2568cc
Bore 86.0mm
Stroke 73.7mm
Performance
BNR34 V-specII N1 October 2000 onwards.
Basic Information
Measurement
Wheelbase 2665mm
Tread (Rear) 1490mm
Curb Weight 1560kg
Doors 2 Doors
Engine
Remarks -
LEV -
Displacement 2568cc
Bore 86.0mm
Stroke 73.7mm
Performance
BNR34 M-spec May 2001 onwards.
BNR34 M-spec NUR Feruary 2002 onwards.
Basic Information
Measurement
Wheelbase 2665mm
Tread (Rear) 1490mm
Curb Weight 1580kg
Doors 2 Doors
Engine
Remarks -
LEV -
Displacement 2568cc
Bore 86.0mm
Stroke 73.7mm
Performance
NISMO S-TUNE
1,064
17
I'll be dame...where in the world that you gather all these infos??!! I salute you....:adore: :adore: :adore: :adore: :adore:
gobiz
926
29
3,028
STICKY please....
kaminari
1,031
43
Taiping
Add other missing/update data for it. Should be it`s translated from GT-R Powerbook :
BNR32
NISMO 560
V-spec 1,453
V-specII 1,303
N1 version 228
Last Production :
STD : BNR32-314649 (7/11/94)
V Spec : BNR32-313609 (13/10/94)
V Spec II : BNR32-313930 (20/10/94)
Annual Production
1989: 4,555
1990: 8,426
1991: 7,081
1992: 7,961
1993: 6,204
1994: 7,465
R32GTR Top Number: BNR32-000051
Wheelbase: 2,615mm
Engine: RB26DETT
* 225/50-16 tyres.
* Less rear wiper.
* Less ABS.
* Less air-con.
* Pull type clutch.
* 225/50-17 tyres.
*245/45-17 tyres.
*V-specII Sticker.
* Less rear wiper.
* Less ABS.
* Less air-con.
BCNR33
Descriptions
Standard 9,871
Sold Unit by years:
95 - 8446
96 - 4093
97 - 2708
98 - 1175
R33GTR Top Number : BCNR33-000001
Last Production :
STD : BCNR33-043740 (9/11/98)QM1
V Spec : BCNR33-043743 (9/11/98)GV1
V Spec N1 : BCNR33-043012 (20/2/98)QM1
- Black (KH3)
- White (QM1)
LM Limited
- White (QM1)
- Black(KH3)
Wheelbase: 2,720mm
* 245/45-17 tyres.
* Xenon headlights.
* Rear fog lights.
Based on V-spec.
* Less rear wiper.
* Less air-con.
BNR34
Production figures 9568 (by 12/2001)
Descriptions Standard: 3714
V-spec: 5812
V-spec N1: 42
R34GTR Top Number : BNR34-000001
- White (QM1)
- Active Red (AR2)
Version 2
- White (QM1)
- White Pearl (QX1)
- Silica Brace (EY0) for M spec only
Wheelbase: 2,665mm
* 245/45-18 tyres.
* Red engine cover.
* Aluminium pedals.
* Less air-con.
* Less rear wiper.
* Less audio.
V-specII NUR
* N1 turbochargers.
* N1 Engine block.
* N1 Piston rings.
* N1 Oil pump.
* N1 Water pump.
farizio
482
37
SUGE!
bagus sekali ade abang kaminari!
domo arigato
ek_elleh
562
21
KB
very useful info..
this one should be sticky..
now i know my halfcut was 1993 year made..
BNR32
BNR32
NISMO 560
V-spec 1,453
V-specII 1,303
N1 version 228
Version 3: 01/01/1993- : BNR32-300001 - BNR32-314649 <----my halfcut within this numbers
1990: 8,426
1991: 7,081
1992: 7,961
1993: 6,204
1994: 7,465
- Cristal White (326) <------ halfcut colour.. still ori..
bit info about the halfcut
-current mileage - 20k.. :thefinger:
(at first i thought 200k..)
acc with halfcut (rough check)
-hks double ssqv
-hks double mushroom
-hks intercooler piping
-hks intercooler
-cusco brake pump stopper
-tein adjustable (front/rear)
now i hope the engine internals also hks/racing parts.. :adore:
wish me luck.. transplant in progress..
5115
Nobody
5,952
2,254
3,213
very useful thread,thanks for your contribution guys.
sticked!
Bump: very useful thread,thanks for your contribution guys.
sticked!
sticked!
samson
59
1,508
Hi,
Was just wondering if anyone knows or has a BNR34 M Spec NUR chassis number?
Just need it to order some parts for upgrading.
Thanks
kaminari
1,031
43
Taiping
Hi,
Thanks
Hi bro,
It`s not necessary to have chassis no. to order parts as long you have the part no, car model and year.Chassis no. can`t be release in public for ordering purpose ;)
samson
59
1,508
I'm aware of that lah.. otherwise why am I asking for chassis number? lol...
Anyways, I found a sample chassis numbers already...
its BNR34-403077
kaminari
1,031
43
Taiping
its BNR34-403077
How i know taiko~ :rolleyes: ...i thought you order stuff for customer, so might get it direct from your customer itself....that chassis number might belong to other owner.So is it PROPER to order stuff using other people chassis no???:rolleyes:
samson
59
1,508
OK. Sorry I didnt make myself clear in the first place. They're parts I'm ordering for an R32GTR, with an R34 N1 engine setup. And about the chassis number,I spoke with the owner, he has no problems about me using it.
cosmicgate
315
35
actually sometimes you need chasis number. Example is someone who is working for nissan but know jack sht about nissan, so instead of asking the year make of the car, they will directly ask u for the chasis number so they can look up in the Nissan FAST program to get the parts number.eg:Display panel LCD for BNR34 before august/00 and after august/00 have different parts number.They actually got no choice, because some skyline owners are newbies themselves.Alot of newbie skylines(not saying all of it lah)dunno sometimes their greencard, the manufacturer date has been tempered to deal with AP issues, this and that, so alot of ppl will just say oh, my car is manufactured in this year*points to green card*. The best way is to get info from NISSAN FAST which almost covers about 98% of the skylines ever manufactured in japan. No one is right or wrong here, ppl at Nissan or Parts seller just wanan make business and the owner is just scared to release chasis number, thanks to all the dodgy ppl who gives malaysia a bad name, forging "new" cars with other ppl's chasis number. In other countries, ppl are willing to freely give out chasis registers because such cases are close to none existance.
Last time i remember i wanted to buy timing belt(almsot all timing belt the same for RB), they ask for my chasis number. Of course i didn't give coz alot of ppl in malaysia can "engrave" your chasis number to track or joint car to make it legal. In the end i just tell them gimme the foking belt
:rofl:
