Rm8k Wira ownership experience-A long way to go
parakey
parakey
1,274
192
663
Now switching to a new cable is more on the softer side compare to the 1st cable. Check & adjust to my specific already. Will test more and check is there still any problems.
Keep an eye on the new cable for some time. You dont want to get caught with pants down again. How much for this impromptu fix?
I had ask the mechanic but he didn't recommend me to adjust the teppet.
He say the car all running fine from his experience. If really one to adjust he say will have some power lost.
Does your car consume engine oil? If not, get the tappets adjusted. It wont rob it of power. In fact, when properly adjusted, you get better performance. While you are at it, check your engine's base timing hasnt been fiddled before.
parakey
parakey
1,274
192
663
How do I describ ah....
Like tatatatatatatatatata. I had ask the mechanic but he didn't recommend me to adjust the teppet.
He say the car all running fine from his experience. If really one to adjust he say will have some power lost. Sorry for my broken English because hw saying in Chinese I had to translate.hahahhahaaha
That tatatatatatatatatata sound normally you can hear from cars climbing hills on too high a gear.
Beyond 20,000 RPM!
Beyond 20,000 RPM!
29,402
8,208
If not getting the performance means loss of power dy, so actually kena rob of power......hahhahhahahha
Beyond 20,000 RPM!
Beyond 20,000 RPM!
29,402
8,208
I juz wanna look clean on the battery site there. Bcoz a lot if wire are attaching to the battery and I dont know what wire is for what.
Or should I say kemas the wire. Have a better wire management. Hahahahahhaha
You try looking for those wire concealer, usually use to hide wires behind those desktop PC. Use that to put your wires in, then will look neat......lol
KHNG940413
KHNG940413
495
39
28
johor bahru
Nope didn't consume any oil. I will go to workshop check after raya.
lsm1991
lsm1991
1,354
157
663
PJ
those cables, in the enginebay ok ka? wont melt? have been contemplating putting those sheaths on all visible cables
KHNG940413
KHNG940413
495
39
28
johor bahru
These are the wire that is attaching my battery.
What I remember some are attached to the reverse camera,see the big white one?direct attach to the alternator.
And other? Not sure what they are use for. Hahahahaha
KHNG940413
KHNG940413
495
39
28
johor bahru
Wira update
So,Otw back home I juz drop by the shop I usually repair my car. Went for adjust tappet.
What I knew after adjust,the sound is much more lower. And it won't have those drowning sound while down shifting(usually have some pop pop sounds in the exhaust
Teken minyak is more linear.
So RM45 well spent I guess?Hahahahahha
Thx for the advice @parakey
gunnerzz
gunnerzz
Jul 3, 2014
1,839
589
713
35
Melaka
Top half of the engine looks very clean.
Your plug cables, make sure its secure to whatever bracket there is on the valve cover, no good to leave it dangling soo close to the extractor.
  • Like
Reactions: minibeany
gunnerzz
gunnerzz
Jul 3, 2014
1,839
589
713
35
Melaka
Just like when i first go the pajero which got some unknown wiring. It already has front spotlight. We went on to add additional fog lamp to the front, rear spotlight, power height adjusted seat from Honda SM4, twin aircond fan, and some other equipment so u can image the added mess.
End up buying proper relay socket and fuse socket, arranging it in a row and at place it wont disturb access to other component, labelled them, properly taped them with wiring tape. Its better now.
I prefer wiring tape as the plastic casing will rot over time.
KHNG940413
KHNG940413
495
39
28
johor bahru
Mine is same as your case. Fog light wire reverse camera wire and other unkwon wire don't know for what purpose.
I am really bad at wire thing so I might as well find someone who know how to sort this out for me and relocate at a better place.
KHNG940413
KHNG940413
495
39
28
johor bahru
Yup,i was suprise is still very clean inside. plug cable I will use cable tie to secure at the valve cover.Hahahahaha
sanekit
sanekit
Dec 9, 2015
1,568
144
163
those are ICE cables/wires, relays and fuse. if not using it, u can just remove.
Beyond 20,000 RPM!
Beyond 20,000 RPM!
29,402
8,208
Wire in engine bay leave it loh. My VR I add a lot of earth wires all over also......hhahhaha
Beyond 20,000 RPM!
Beyond 20,000 RPM!
29,402
8,208
You saw how the man did it. Next time you can invest in a set of feeler gauge and DIY
My daughter's tool box have, but I have never attempt to adjust. Need to know how and how much to adjust, but anyway my VR is hydraulic lifters, probably same goes for my hyundai. Chery never touch, Subaru worse, cannot reach......lol
sweelt
sweelt
Nov 6, 2016
2,226
218
163
Penang
cons of doing swap when u lack experience and you're not familiar with the workshop. because of this, i had to learn about cars. i had zero knowledge about cars before i did my engine swap. hahaha. thanks to @Izso and @vr2turbo and the other gangs for helping me build up my knowledge.
you can read through my old thread here - http://www.zerotohundred.com/forums/index.php?threads/need-advice-4g93-sohc-auto-semput.460300/
same here :smokin:before engine swap i duno shit about car diy. My mech ocassionally "hengggg" which made me start digging google, digging from group adviced and diy.
  • Haha
Reactions: sanekit
