Rm8k Wira ownership experience-A long way to go
KHNG940413
KHNG940413
486
39
28
johor bahru
Go back to stock la. Excedy maybe too hard? I dunno. Get something with a lot of springs.
It's not part of the drive shaft replacement but if you wanna do it might as well do it together. Maybe save on workmanship
Yup,I wanna save workmanship. Hahahahahaha
For clutch more spring more soft? I still new in manual area. So dunno the difference.
lsm1991
lsm1991
1,348
157
663
PJ
New one. Diagnose already. Ni problem juz always the speedo & high voltage issue always pop up only. My fuel filter had been changed.
May I know if chg drive shaft will they open the gearbox? Is so I also wanna buy a set of clutch set and ask them to help me install while changing the drive shaft.
just saying, tukar shafts noneed to bukak gearbox
tukar clutch memang must bukak.
tldr: you hardly save on workmanship together or separate...
parakey
parakey
1,272
192
663
My mechanic say is the drive shaft rosak.
Changing a pair of drive shaft + gear oil + gearbox oil seal ( forgot the name, some seal put at flywheel or clutch something.)+labour=RM650
Is it the price reasonable?
I recently replaced RH driveshaft for my 1.8. Driveshaft - rm175, Gearbox oil + labour is another RM130.
Beyond 20,000 RPM!
Beyond 20,000 RPM!
29,373
8,203
Exedy clutch got normal and performance mah. My VR have been on Exedy even since, very light only......
Beyond 20,000 RPM!
Beyond 20,000 RPM!
29,373
8,203
Yup, correct. Change drive shaft is one charge. To change clutch need to drop GB, different charge already......lol
Beyond 20,000 RPM!
Beyond 20,000 RPM!
29,373
8,203
Mine I juz consider to chg back to stock size. Although my friend call me to upgrade to a 8&8.5 inch clutch. What are the difference?
I mean 7.5 inch vs a 8 & 8.5 inch clutch
Most people go bigger for more contact. Unless your mod your engine until so powerful the clutch slips, then probably can consider. But if not, why bother, wasting time and money. Like I mention, even after my engine swap to 200bhp, still using normal Exedy clutch only......lol
sanekit
sanekit
Dec 9, 2015
1,565
144
163
if change bigger clutch, need to change bigger flywheel ah?
KHNG940413
KHNG940413
486
39
28
johor bahru
Wira update.
I had bought apair of drive shaft +oil seal=RM290
Labour+gbox oil=Rm150
Total RM440. Yup save a lot of $$$ when you go outside and buy yourself. Hahahahahah
