Rm8k Wira ownership experience-A long way to go
KHNG940413
KHNG940413
548
43
28
johor bahru
Why change the whole compressor for recon unit if only the magnetic clutch got problem? Compressor working fine.....:driver:
The 1st mechanic I go to check say compressor rosak. I dun belive so I bring to another place to check. Found out only the old clutch rosak only.
So I juz change the clutch yesterday and everything is ok now.
LittleWhiteWagon
LittleWhiteWagon
1,657
187
P.J
To be honest. What were they thinking making the car so high.Hahahahaha
It gives better suspension travel & comfort for consumers. Back then when cars were still relatively softly sprung, they can absorb bumps very well in a straight line & mid-corner. I've a feeling why it wasn't lower because of ground clearance when fully loaded.
But then again there's a lot more engineering behind that than just how high/low soft/stiff a car is that makes it handle... Our IRS proton rears under compression gains camber + toe. Quite a good design for that era.
  • Like
Reactions: sanekit
LittleWhiteWagon
LittleWhiteWagon
1,657
187
P.J
Stand still pick up ok la.
Juz lack a bit of torque after you release the pedal and step back.
Now my friend suggest me to go and check does it need a top overhaul. The engine is running ok but when driving & idling a little tapping sound.
If you want to save cost can perhaps try diesel engine oil at the next oil change first. The engine may be a little dirty over the years.
I've used bardahl diesel oil + marvel mystery oil to revive a 3 years dead wira. From blowing white smoke it took 1 week of driving to get it to have 0 smoke & condensation like new in the morning. Sometimes the piston rings are just a bit sticky, don't necessarily have to overhaul straight. :burnout:
  • Like
Reactions: sweelt
Boooooossst
Boooooossst
15,019
6,314
ah finally a proper 4g1x taiko is in the house
  • Like
Reactions: sanekit
Beyond 20,000 RPM!
Beyond 20,000 RPM!
29,585
8,263
My hyundai change oil from 10w40 to 5w40 started smoking. Now Change to 20w50 with a bottle of no smoke to keep it from smoking......lol
gunnerzz
gunnerzz
Jul 3, 2014
1,914
613
713
35
Melaka
Eh, now people move to electronic cigarette. No more conventional smoking. Maybe u can try few drop of vape flavor into the engine oil...adds some taste and aroma...hahahah.
sanekit
sanekit
Dec 9, 2015
1,611
156
163
#offtopic can try heat not burn ciggies too. but the starter kit cost like RM200-350 including the heat sticks.
Beyond 20,000 RPM!
Beyond 20,000 RPM!
29,585
8,263
Better not, behind fellow get second hand smoke.....hhahahhahahha
KHNG940413
KHNG940413
548
43
28
johor bahru
For now my wira 1tank can go around 400km RM80+ a tabk. So far so good now. Next month will go and check some issue. The car suddenly engine mati. Dunno why everything still on. Push to N then start back is ok.
My suspect is the fuel injection. Since if is fuel pump issue the car will goyang very kuat because hard to pump the fuel,but my car didn't have such problem. Will diagnose agn when checking.
Boooooossst
Boooooossst
15,019
6,314
Have you changed the fuel filter?
