recommend miniDSP's nanoDIGI_2x8-B
Acoustic
1,295
52
Hong Kong
www.my-acoustic.com
Hi guys,
I recommend this miniDSP's nanoDIGI_2x8-B
I'm using one at home now. Later in the future will run in car. It can run off 12vDC. >10 years ago already running below in my car using invertor. no limits - pro audio DSP in car 2003
Since nanoDIGI_2x8-B is digital outputs only, couple with pure digital driver (direct digital amp = power DAC) [no DAC inside]
something like
http://detail.1688.com/offer/42455189377.html?spm=a2615.7691456.0.0.BBmEdF
or
https://world.taobao.com/item/43291747349.htm?spm=a312a.7700714.0.0.Tjx8NU#detail
They run as high as 36vDC hence need DC amplifier to convert upstage.
then system setup as this example good example setup - Hi-Fi - orthodox
Acoustic
1,295
52
Hong Kong
www.my-acoustic.com
I'm using a slightly more updated version of what you're using.
It's not the same thing, not doing the same task, hence not comparable, right?
Wait.. yours is a DSP?
Sorry.. You're right. Not same thing at all.
Right now I'm using the Tunebox connected to a Bit10 using optical which is a DSP. Close enough :biggrin:
I am currently driving a satri 1.3GLi. I have been experiencing problem with starting my engine. It usually takes 2 to 3 kicks before my car starts everytime my engine is cool. Does anyone else experience the problem? I have sent it to a few mechanics and also EON and they say nothing is wrong. Hope you all can help. Thanks.
