R34 GTR MFD unit..
[PIMPIN]
2,138
648
3,213
Got a question for those using the Nismo MFDII on a BNRGTR34, have you guys tried the lap timer function? I thought that it was connected to the button on the gear console, but mine doesn't work. I'm thinking it's improper wiring, but a tad lazy to open up everything to confirm.
Or is the button for another feature entirely?
I have the same problem. That is if we're referring to the same button. It's a small button beside the gearshift, mounted on the console but closer to the driver right? The wiring for mine is dodgy but then again, it does not seem like the best place to mount it right.
Dude, Nismo MFD is the same as the little monitor inside your GTR, except their software are little different from standard GTR's. Nismo version have extra function like, Lap timer, G-Force measurement, and etc...The best is, when you starts up your car, the LCD displayed both "GTR" and "NISMO" wording at once!
Also you have increased 'range' in terms of the measurements displayed. If I'm not mistaken, the stock MFD boost goes to 1 bar thereabouts? (someone correct me if I'm wrong - never had the stock MFD) which requires more gauges etc. The Nismo one goes up to 2 bar so that's one gauge less for me (for now!)
eh, where can i get the nismo mfd upgrade?
is it compatible with aftemarket ecu?
Yeah, its definately compatible with aftermarket ECU. I've used both L and DJetro versions of the PowerFC and MFD works fine.
However, I have the software and cable to connect laptop to MFD but sadly its in Japanese. Kaminari, come translate!
kaminari
1,031
43
Taiping
lately i`m being so lazy~......... like reading your guys cyber TT
You don`t need that crap analyser... u like to see graph done on street road?heee....this software only works on ODD lappy .....i means WIn 95,98 and NT4.0 only.:sleep:
NISMO S-TUNE
1,064
17
Correct Pimpin...thanks for adding in..the boost in Nismo version can goes up to 2 bar whereas std MFD only can reached 1.2 bar! :itsme:
shiroitenshi
3,676
170
Actually, it's a diy install affair. So kaminari, what is the option button for? From the manual, it appears to be the lap timer (I think) or did I assume (can't read japanese 100%) it wrong?
I guess, I'd have to pull out the console and check the wiring then. Thanks.
BTW, isn't there two versions of MSD? One for the GTR, and the other for non-GTRs?
The sensors included differs between the two versions, isn't it? (forgot the actual sensor included for non-GTR models.)
From the above discussion, it seems like everyone is thinking there is only one version, at least to me?
kaminari
1,031
43
Taiping
Why not you post up the manual part so we can verify it.From my experience,it`s the lap time switch.
Yes got 2 NISMO MFD version for GTR and non-GTR(vspec,nur,m spec) which the normal GTR kit would come wth Exhaust temp sensor.
omaroDDin
263
wooo....
yo pimpin, where can i get the upgrade?
def gonna get it now.
alvinT
222
did anyone in town know how to install this thing??
is this MFD just support Power FC or any other aftermarket ECU??
alvinT
222
sorry bro semperfi...
i'm a newbie here...actually my question is refer to GTT...
so i'm not sure whether anyone around know how to install and setup the MFD...
how bout piggyback? does it function? or only got to be standalone ECU?
semperfi
126
8
Worldwide
Sorry, I thought you were referring to GTR. Rizalaris posted on page 1 but it depends on the sifu itself if he can really install it for you. Gotta ask around some boys here. They might know a thing or two. good luck!:wavey:
V-Spec
1,861
170
5,163
The MFD will still function if you have a piggy back or a standalone ecu. Not sure who can do it here in Malaysia but I have a copy of the wiring diagram/guide if you wanna embark on this costly project. :)
Hey guys. Need to find out something here, hope someone has experience in this.
Is there a specific kind of bosskit for Proton cars (Wira, Satria) originally with airbag equipped? I've been told that for airbag cars the kit is different.
Where can I find such a boss kit?
Thanks in advance.
